Timing
  • Brushless01
    • Apr 2010
    • 489
    Timing
    What should the timing be on a seaking 180 amp speedo and a Neu castle 2200kv ?
    Thanks
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
  • m4a1usr
    Fast Electric Addict
    • 2036
    I'm running something vey close, Turnigy 180 and the castle/neu 1515 1Y, in a rigger and I left the timing at the default (15 deg). Seems fine as is. Very little heat. Havent dialed in the hull 100% but its alright for now. YMMV but its alright in my setup.
    John
    Change is the one Constant
    • Rumdog
      • 6667
      I ran the same esc and motor at 15 deg. and it works great. Little heat, good performance.
      • Alexgar
        • Aug 2009
        • 3701
        i run at default 15 with that setup in a vee
        • Brushless01
          • Apr 2010
          • 489
          Thankyou. It will be in a delta force 29 any ideas of props or speed ??
          • Brushless01
            • Apr 2010
            • 489
            Also what should the LVC be set at for running two 2 cell lipos in series ??
            Thanks
            • Alexgar
              • Aug 2009
              • 3701
              4s on the lvc
                4s on the lvc
                4S is the number of cells in series. The LVC should be set between 3.2 and 3.4 volts. Try 3.4 volts first - if the boat cuts out then reduce to 3.2 volts.
                • Brushless01
                  • Apr 2010
                  • 489
                  Thanks
