I recently tried a new set up in a BJ26 since I burned my BJ components quite some time ago. I was running a china motor, 2045 on 3S, 60A esc and a 637 prop and it was only gps slower than the stock BJ set up on a 642. Visually, I couldnt tell a difference. Anyway, 2 days ago I swapped it w/ a Turnigy 3656 1800KV motor and put it back on 4S using a Turnigy 120A esc. I left the 637 on it for testing purposes. I set the timing at 0 degrees.
After one run of maybe 3 minutes, Batteries were at 96F and 101F, ESC was 103 and motor was 148F. Whats the general cause of only a motor running hot? I bumped the timing to the next interval which is 3.75 and it brought the temps down about 10 degrees. Am I on the right track doing this? Should I go to the next interval of 7 degrees?
Also, and ironically, This afternoon I got my Genesis back in the water after some minor mods and swaping the shaft out to .150. Im running it on an Etti 150 OPTO, 4S, 0 degrees timing and am using the stock 8XL motor. Temps were common from my BJ run. Batts were 101 and 102F, ESC was 112 and motor was 137F. A bit of smoked puffed out and she smelled a bit. I know its not the choice of motor but its what I have to use for now. Oh this was on a X440 prop and it ran teriffic!
I just want to find out if high motor temps when nothing else is warm is a timing issue or is it cheap motors?
Thanks,
Scott
Thanks,
Scott
I figure I can poke around w/ timing and find what works best, mostly Im curious about the abnormal temp difference compared to the other components.
