I am not able to arm or calibrate this 120. I have the bec disabled and running on a s-bec. SR3000rx DX3.0tx feigao 9xl(hooked up). All the esc's settings are @ factory default but a custom lvc of 12.2. The esc was linked fine to my pc and accepted data. Turned on the tx and connected the battery as stated in the guid and all I get is a red flashing led..No programing or arming. IDK..my first one & am clules. Any ideas anyone?
Hydra Calibration
Did this one get figured out? Had kinda same thing happen with CC80. Hoping maybe it was something simple overlooked.
Your killin me..lol. Well it don't work any way. Young Mr Smock suggested I disconnect the s-bec and battery using a receiver pack. Same result. A fashing red led with no responce(beeps) & nothing from the motor what so ever. All my end points are maked..trim is at 0. I have played with the netural position by just moving the throttle forward and back a couple degrees..NOTHING. I don't have a hex preped to swap it out and only have 2 or so hours left free this afternoon. Looks like i'm not making the water today...
I have had to screw around with my transmitter settings on some Castle ESCs to get them to arm. My Barracuda 180 (don't ask!) needs these transmitter setting on the HiTec Aggressor SRX:
Trim +70
Forward +125%
Brake -125%
The trim setting is usually the issue. Try different settings (write them down) until the ESC will arm.
Good suggestion. It jogged my memorey as to the settings I needed with the Sv. I tried to arm it 20 times between setting 0 & 100 same result. Drained a transmitter battery in the process. I am @ a dead end. I guess tech suport is my last option tomorrow. Either way I am still not running today.
weird I have several castle esc's and mine recognize once i turn on the radio.
I have a JR and it sees it from total neutral.
