Prop nuts
  • Rex R
    • 1007
    Prop nuts
    the Q has come up. the standard 5-40 lock nut is 0.25" across the flats which means the points over hang the prop hub a bit.
    Question
    does this make any difference to you the boater? or would you buy them anyway just avoid losing the prop?
    I know what my choice is, am looking to see what the rest of you think. thank you.
    rex
  • FRED
    • Jul 2007
    • 232
    prop nuts
    I just take to grinder and grind the points off to where i can grab with a pliers to tighten and then use a small water line hose after the nut is on and one hose piece between coupler and stuffing tube so as not to loose the flex and prop.
