Let's See How Smart Everyone Is...
    • 7512
    Motor suggestions please;
    Requirements;
    1) Brushless outrunner
    2) Relativily inexpensive
    3) Power will be a 2S 5000mAh 20-30C Lipo
    4) Pushing a 56" mono, 13" wide
    5) Weight of boat will be approx 30 Lbs
    6) Turning a (approx) 35mm prop.
    Lets hear your suggestions.
  • BakedMopar
    No Mo Slipah
    • Sep 2009
    • 1743
    I should give my mouse DeCon for clicking on this thread.
    • Boatman
      • 875
      Sad thing is if we could get someone to machine and produce a quality transmission (geared) for us that would be possible. Some of those heli's are getting pretty big and powerful.
      Edit: Your speed goal was not given. :)
      • Flying Scotsman
        Fast Electric Adict!
        • 5195
        Not cheap....A Honda 50hp outboard...might be a little heavy on the transom though
        You have to use a transmission and a larger 3 bladed prop...speed 5mph ...smart ass Douggie.
        Edit
        or a motor with about 100kv... and two dogs with a towing rope.... speed 1.5 mph... double smart ass Douggie....Love you Doby
        Douggie
        • domwilson
          • 4412
          I would start with a 32' cat. Twin 850 hp engines and a good tow rope. Should get you over 50 easily...
          Government Moto:
            • 7512
            Ironically, this is for an actual project of mine....speed expectations will be around 5Mph.
            • Jeff Wohlt
              • 2740
              If those are your speeds then a good, cheap big outrunner with 6S could get you there with a big prop. What is it a kiddie ride..LOL.
              www.rcraceboat.com
              jwohlt5362@yahoo.com
              • befu
                • Aug 2009
                • 1064
                Requirements;
                5mph? Will it even get on plane? Or is it a displacement hull. 30 lbs is really heavy for a 56" mono. Heck, even the old dumas 55" hull was about 9 lbs and that is one of the heaviest boats I have seen. Nice, but really heavy.
                I wouldn't think it would be that hard. Why do I say that?
                Back in the old gas days before zenoah and modified homelites, you could get a large heavy boat going mid 20's with a cheap weed eater. Some faster, but I remember this 55" cat that we made out of a dumass 55, cut in half and used marine 1/4" ply for the sides and tunnel. I think it weighed in around the mid 20's. We pushed it with a stock 25cc weed trimmer, was slow and slugish but it planed out and probably went low to mid 20's. Used a larger prop, maybe 482 to 472 octura. Those weed trimmers only put out about 3/4 to 1 1/4hp.
                So, onto your idea. 30 lbs is really heavy, not sure it will plane at 5mph. But on 2s and a x482 prop, 300 kv gives a theoretical of 9.5 mph, which should put you close.
                http://www.hobbyking.com/hobbyking/s...idProduct=5204
                This is a 50mm dia outrunner at 270kv and it is on sale at $26. The problem is the wattage available on 2s. 7.4v at 60 amps is only 444 watts, or 6/10 hp. Might work for 5 mph.
                Here is a 63mm outrunner, 235kv for $45
                http://www.hobbyking.com/hobbyking/s...utrunner_235Kv
                A 50mm turnigy, $40 and 270 kv
                http://www.hobbyking.com/hobbyking/s..._270Kv_/_2100W
                I think it is doable, but need more information. What hull are you looking at? Planing or semi displacement? Like a sport fisherman? Maybe twins would be in order. Is that battery set and only one? What run time or are you looking at 3-4 minutes for up to 700 watts available? Doable, but that is a lot of amps for a 2s setup, and a lot of weight for a 56" boat.
                Sorry for a lack of emoticons or quips in this post, kind of broke with the above tradition on this one.
                Brian
                  • 7512
                  Thanks Brian, thats what I was looking for.....kind of...
                  This is what it is going to power..........as an auxillary motor
                  • befu
                    • Aug 2009
                    • 1064
                    Oh, that changes everything. Yeah, I would think that would work out no problem.
                    I have seen a couple of discussions over on rcgroups on the scale section about how much power to put into a given hull. They even had equations with variables and technical sounding stuff! They might be able to help you out there.
                    You have a very efficient displacement hull there, should be easy to power with a 2s battery and have it motor around for a long time.
                    Opps, just noticed the 35mm prop, missed that the first time around. You are going to need a much smaller outrunner. I wonder if one of those mystery 2836-1700 kv with 30 amp esc would work for this? They turn a 35mm prop on the cracker box easily. They also make a 1000 kv version which might be better.
                    Sorry I missed the 35mm prop detail.
                    • Jacked1
                      • Jun 2010
                      • 787
                      Just get a cheepo drill for 20 bucks on ebay and you could use the chuck to go strait to the drive shaft.
                      I used two for my 2nd version of my old pos villian when i was 12! Didn't use the chuck tho.
                      And i used a trigger from the drill as a speed controller. I think it would be a good power system for a retrieval boat and a small 12v lead acid battery.
                      • Flying Scotsman
                        • 5195
                        What a great looking boat, is that scratch built?
                        Douggie
                          • 7512
                          Hmmm...interesting.......never thought of that, I do have a few old drills laying around.
                            • 7512
                            Douggie
                            Nope, its a kit , on order from a company called Robbe....they are in germany (I think) should be here in a few weeks.
                            Should make a great winter project
                            I have enough FE boats ,,time to get back to some scale and sail boats!
                            • Jacked1
                              • Jun 2010
                              • 787
                              Yea the drill would not have a problem moving that prop.
