Thanks guys for all the info. I just came back from the pond and ran both packs-I ran the 2 low packs and after 2minutes boat slowed. Ran the 2 high volt packs and the boat ran for 5 min no problem. I think you all got it right. Bad pack. Charging all 4 packs now will check for the low /bad batt. I'll let you know what I find.
They should charge to 8.4v. If you have 2 batteries that are only charging to 7.xx volts, dont use them. Continue to monitor your other batters and make sure its not your charger that is improperly charging these batteries.
The batteries that arent charging properly are not going to be able to supply the current needed, which will put a substantial load on the other battery that it would normally not have. Continuing to run these would also almost definitely cause an esc failure.
Even my cheap turnigy accucel 6 on balance charge will charge each cell to 4.2v. (or max. usually 4.19 -4.2v)
If you have 8.41v per pack, that is a bit high for my taste(some say that anything over 4.2v per cell is too much) , are the packs soft/do you feel air inside them?
And you do charge them seperatly?
23428mah ? must be a typo that one
No balance no pack will last too long. do you balance them?,
No balance no pack will last too long. do you balance them?, ,-or is that charger not capable to show cell voltages?
Found the problem with batts. Cold solder on one of the wires from motor. resoldered and everything works great and motor/esc run much cooler. Batts charge properly now. I pulled on all the wires from motor and one wire fell off.
Thanks guys for all your expertise.
