bearings vs bushings
  • scubasteve95
    • Apr 2010
    • 245
    wharts the story????
    i use bearings but one locked solid (like a bushing)and had no
    affect on the speed or the shaft.
    should i just go with bushings and not have to deal
    with the bearing??????????????????
    please keep it friendly....im just asking.
    sorry about the double thread.
  • Himalaya
    • Apr 2009
    • 259
    There are a lot of thread discussing about bushings and bearings. Many prefer bushing and I totally agree with them but I was just not having good luck like them on bushings. Now all my 4 boats from 58cm to 140cm use bearings and I love them. Normal bearings do lockup every time after each run if you leave it without maintain. For me getting it dry and one tiny drop of oil don't look like a huge job. That will keep it smooth for a long time. Once really broken, they can be replaced as easy as a finger snap.
    The thing that makes me love bearings is they keeps ZERO PLAY/Wobble during their whole life. That means a quieter, more efficient, and more acurate running boat. Bushings, on the contrary will run perfectly at the beginning but then...... again, that's just because of my bad luck.
    • graill
      • 407
      Personal preferance, nothing wrong with a well maintained and well built bushing setup. Myself i use all hybrid ceramic, stainless steel race, ceramic balls.
      As cheap as most of the bearing are there is really no excuse as they can have them made for any spec you need, in fact the selection today is huge. Granted the occasional odd size can cost a bit. Plus bushings cannot take the same abuse a bearing setup can, nor can they achieve the rpm a bearing setup can achieve reliably. All things being equal a bushing verse a bearing in the same setup, the bushing will gall before it achieves final step rpm the bearing can handle. :)
      • Jeff Wohlt
        • 2740
        Good bearings all the way for me. For wire drives it does make all the diff.
        www.rcraceboat.com
        jwohlt5362@yahoo.com
        • scubasteve95
          • Apr 2010
          • 245
          THATS WHAT I WANTED TO KNOW.
          and from a source i know and trust...thanx
          boca ultra seal ceramic here i come......
          FLANGED #SMF74C-YUU NB2 ------ 11.95ea x 2
          NON FLANGED #SMR74C-YUU NB2------9.95ea x2
          • jimbo--jones
            • Jan 2010
            • 58
            bushings are water bearings, way better in my opinion. it makes a thin film of water between the metal, so once in the water they are almost frictionless. also way less maintenance than normal bearings
            • scubasteve95
              • Apr 2010
              • 245
              what do you think of the
              boca ceramic ultra seals?
              or what would you recommend.
              not to sound to snobish.....im not to concerned with price
              just want top quality.i plan on upgrading soon so i want to be ready.
              (cant get forescotts 57mph run outta my head.....)
              • TotalPackage
                • 622
                Some gurus I know use needle bearings in their struts with great success.
