LiPo lead failure
  • Insaniac
    • 496
    LiPo lead failure
    This was a cold solder joint that came apart on a Flighmax 5000mAh 4S pack. I can see the pad on the circuit board inside. Can this be re-soldered? Do you need a "special high temp"solder?
    Support US hobby suppliers
  • vasy
    • Dec 2009
    • 348
    had this, I just used regular electric solder and it worked well.
    Just need to have good soldering iron.
    • Gary
      • Jan 2009
      • 1104
      I have done the same with no problem. Just use caution........you dont need any mishaps with your face that close while working on it.
      H&M 1/8 Miss Bud 73 mph
      Chris Craft 16 mph
      • Insaniac
        • 496
        Thanks, I'll give it a go...
        • BHChieftain
          Fast Electric Addict
          • 2051
          This just happened to a friend of mine today on a 4s 5000mah pack. I think it was the same brand.
          Chief
          • Insaniac
            • 496
            Soldered it back together and it works fine...thanks!
