32" Cat, 65 mph, 3+ min runtime ; Do-able ?
  • BakedMopar
    No Mo Slipah
    • Sep 2009
    • 1743
    I can't comment on the 65mph as I don't think any of my boats go that fast. I will however comment on "MY" experience on the Turnigy batteries. I have said it for a while know and a lot have disagreed with me. You are spot on Tony! Without going into detail, when the packs are new and fresh they put out good power. Give them a few cycles and performance starts to degrade. These are 40-50c.
    • JMSCARD
      • Mar 2010
      • 4174
      Jason, the packs were Turnigy 4S 3600 30/40 C. The answer may be hidden in the C rating. The Turnigys [ not the newest higher rated ones just released] have the burst rating at ten "C's" higher than the "Constant" rating, while the premium packs, like Hyperion and TP's have the Burst rating at twice the Constant rating.
      I believe that therein lies the difference. Don't get me wrong, I have lots of Turnigys which I use all the time for fun running, but when max performance is required for racing I use Hyperions.
      I'm sure you guys are right.... I don't have ANY race experience whatsoever... and I am sport running where I am on and off the throttle all the time... never just full bore for long long periods..... for my "short bursts" the turnigys work fine... I do want to try some hyperions though as they are the one battery that everyone seems to agree on... that they are very good....
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3784
        If sticking with the R2 32" cat hull... get good with fiberglass. The whole side just cracked apart... sitting in the sun to let the paint dry. The top/bottom seam split.
        • MarkF
          dinogylipos.com
          • Mar 2008
          • 988
          If you guys want the absolute best performer then I recomend Thunder powers new 45c packs. This is all I use.
          Mark
          • properchopper
            rcgoatbuild@snotmail.com
            • 7708
            Mark
            My next batt's will be TP for sure.
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3784
              Any updates? I finally finished putting the 15xl in the R2 cat hull. Unfortunately don't have a GPS right now though.
              • properchopper
                • 7708
                My friend is running a UL-1 motor now. He's starting to see the light [I think]
                • LarrysDrifter
                  Big Booty Daddy
                  • 3416
                  I've been asked by a new friend to help him select components for this project : Using an R-2 32" cat hull [google it] on 5S, he's looking for 65 mph, 3 plus minutes runtime [ I talked him out of 5 minutes for obvious reasons] and not a budget killer. I have no idea what to tell him, partly because my experience is primarily with 4S setups and P class raceboats. My gut tells me this is not realistic, but any fact/experienced based suggestions on motor/SC would be appreciated.
                  My friend has a 32" Apparation cat with a 540XL motor.Its 1050kv on 6s with a Turnigy 180 amp esc.Its run on 6s with an X442 prop.He run 64 mph with no heat issues and almost 10 minutes of run time.Its a nice set up that isnt overly expensive and doesnt get hot.
                  • BakedMopar
                    No Mo Slipah
                    • Sep 2009
                    • 1743
                    10 minutes? Wow. Is that constant running?
                    • LarrysDrifter
                      Big Booty Daddy
                      • 3416
                      Pretty much.Ill ask him what the exact time is.Im just guessing,but it is more than 5 minutes,I know that for sure.Its a very good running boat.
                      • properchopper
                        • 7708
                        Thanks for the info- I'll pass it along
                        • properchopper
                          • 7708
                          Larry, I was looking in the OSE motor store; no Feigao 540XL 1050KV motors listed ; the 580 12L is 1051KV. Could that be the motor ?
                          • Diesel6401
                            Memento Vivere
                            • 4391
                            I have a 580 7L for sale in swap shop, perfect 5s motor.
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • LarrysDrifter
                              Big Booty Daddy
                              • 3416
                              Its a 540 motor.Ill ask him what brand and where he got it.Ill get back to you on it.
                              • Diesel6401
                                Memento Vivere
                                • 4391
                                Their a 540xl 16 turn rated at 1042kv http://www.offshoreelectrics.com/fei...tors-chart.php, steve does not sell those though.
                                Just tryin help, hope you guys don't think im thread jacking.
                                - Diesel's Youtube
                                - Diesel's Fleet
