Good 6s-8s outrunner?
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3480
    Specs I'm looking for:
    540 size mount holes (fits in my water cooled mount)
    <50mm wide
    <75mm long
    2,500 + watt rating
    5mm or 8mm shaft (prefer 5mm)
    6s-8s Kv rating for 24-30k rpm. (1000 - 1500kv range)
    Shooting for a low RPM, high torque, big prop setup. (32" single cat)
    Any suggestions?
  • scoota
    FE DOWN UNDER
    • Dec 2008
    • 409
    a hyperion -4025 / 890 kv , can handle 8s , which will give you 25000 rpm , i am runing one in a 540 water cooled mount , they are rated @ 2700 constant WATTS & 3700 max peak WATTS
    jason
    UL1- 1515 castle/neu / 240 swordfish
    SV27- with UL1 running gear
    33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3480
      jason
      That sounds perfect. The next question is where to get one. Google didn't help much.
      • scoota
        FE DOWN UNDER
        • Dec 2008
        • 409
        oh they are a 5 mm shaft ..
        jason
        • scoota
          FE DOWN UNDER
          • Dec 2008
          • 409
          Im in Australia & i got it off my local Hyperion dealer , search Hyperion , i will try & find a link for you
          • scoota
            FE DOWN UNDER
            • Dec 2008
            • 409
            Here is a link , it has where to buy at the top of the page , hope this helps ....
            Jason
            • scoota
              FE DOWN UNDER
              • Dec 2008
              • 409
              Empire Hobby, is the US dealer .... they do make a 1100 kv motor in 4025 range , but it can only handle 5-6s & is rated @ 2200-2970 WATTS , i would go for the 890kv motor myself ....they have a 4035/4200 WATT motor range , but they will not fit in the 540 water cooled mount ....
              jason
              • FighterCat57
                "The" Fighter Cat
                • Apr 2010
                • 3480
                Nice! Thanks!
                What kind of performance are you getting from the boat it's in?
                • scoota
                  FE DOWN UNDER
                  • Dec 2008
                  • 409
                  its in a DF mono , gpsing over 60 mph & the sound the outruners make is wicked !!!! Im doing a lot of testing with Hyperion products with the help of my dealer at present , there lipos are some of the best batteries i have run so far ... i know they are working on a new range of inrunners as we speak , cant wait to try them out as well ... all the outrunners are 90-95 % efficient ...
                  • JohnZ
                    • May 2010
                    • 254
                    You also may want to check out Scorpion Motors @http://www.innov8tivedesigns.com/
                    They have a line of high power heli motors.
                    BTW Scorpion also manufactures motors for Hyperion.
                    I use both for my planes....yes I fly RC planes too, and like both brands. In fact these two brands are the only ones I use now, replacing old Axis with new Hyperions or Scorpions.
                    good luck!
                      • 7990
                      It appears that the Scorpion and Hyperion outrunner motors are the same - at least some are. For example the 4025/1100 motors have the same specs and look identical except for the colours. I run a Scorpion 4025/1100 on 6S and like it a lot. Rated at 100 amps on 6S it handles more if fed enough air. It runs high 40s on 6S1P in a SprintCat 40 for a nice sport setup. On 8S the 890 Kv version might be a better choice.
                      • scoota
                        FE DOWN UNDER
                        • Dec 2008
                        • 409
                        You are right in saying that they are the same Fluid , call me one eyed , but i get better back up with Hyperion & better prices , i cant stand the guy that sells Scorpion stuff over here & he charges more for the same product . Yes the only down fall with the outrunner motors is they designed to have cold air flow into the front fan of the motor , which is a problem in a hull with its hatch taped down , i try not to run mine more then 2- 3 minutes at a time ,to keep the motor temps down...
