Miss Vegas as a LSH Hull
  • JimClark
    • 5913
    Looking at getting a LSH hull but most of the used ones out are just too small IMHO
    Looking for something close to 30 inches and was wondering about the Vegas Hulls converted to FE. Who has converted and run them with todays spec power and lipos?
    How did it Handel it and how does it work for a LSH Hull?
    Jim Clark
    Billy Graham
  • Shooter
    Team Mojo
    • Jun 2009
    • 2752
    Hi Jim. There are a ton of us out there that have converted these. Do a search on "Miss Vegas FE". Unfortunately most are far from spec. The Vegas hulls are very unaggressive and require a lot of power to push through the water. Very heavy. BUT, they are very stable IMO. You won't be upside down as much!
    • detox
      • 2357
      The new version Miss Vegas Deuce has more AOA built into sponsons. This will make it run more loose and be faster. Perfect for LSH ...IMO.
      • Diegoboy
        • Mar 2007
        • 7443
        Jim,
        I was considering this one before I got the BBY Zephyer27
        31" long
        • JimClark
          • 5913
          I just asked about the Vegas as there aren't any glass shovel/roundnose hydros out there which is what I would prefer
          Billy Graham
          • BakedMopar
            No Mo Slipah
            • Sep 2009
            • 1743
            I hear you Jim. I had a hard time finding glass shovels too. Eighter too small or too expensive.
            • Shooter
              Team Mojo
              • Jun 2009
              • 2752
              Originally posted by Diegoboy View Post
              Jim,
              31" long
              Randy also makes a 30" sport hydro. I think there are pics of it somewhere on the forum. BBY 30" Hydro.
              • Boatman
                • 875
                I ran my vegas in spec heat racing and it was a dog. With BJ26 motor and UL-1 motor. Speeds were about the same using 45mm and 42mm props. In my opinion it would need a good 6S1P setup. Perhaps a Feigao with proper kv would be ok. Other than that it handles great and turning is ok with stock fin.
                • Shooter
                  Team Mojo
                  • Jun 2009
                  • 2752
                  No doubt. This boat craves more power. I'm running a Neu 1515 1Y and it is an absolute bullet at over 60mph! Stable running.
                  • JimClark
                    • 5913
                    Ok this is a dead issue then that is what I wanted to know.
                    Thanks for the info
                    Jim
                    Billy Graham
                    • Hydromaniac
                      • Oct 2007
                      • 955
                      Jim, not to many shovels out there that are good with the brushless power yet, and nothing that is close to scale, I have built a couple in the 32 inch range from Finlay plans. They have worked well.
                      www.rockymountainthunderboats.org
