Hobby King Cat (Surge Crusher) hull repair
  • Graeme
    • Jun 2010
    • 97
    As some of you know I got home from my last run and discoverd cracks in the hull of my Surge Crusher. I decided to try and fix it. I may have gone a little over board with the repair but It won't break again.
  • Graeme
    • Jun 2010
    • 97
    I cut the motor mount out with a dremel and ground down around the cracks.
    Then started with a layer of fiberglass.
    Ground down the high spot so that the wood would sit flat
    • Graeme
      • Jun 2010
      • 97
      [ATTACH]29740[/ATTACH]
      [ATTACH]29741[/ATTACH]
      [ATTACH]29742[/ATTACH]
      • Graeme
        • Jun 2010
        • 97
        I ordered a motor mount off ebay as i cut out the stock one.
        I am not sure if I will wait for it will probably fabricate one.
        next I need to fill in the cracks in the hull sand smooth then I am goind to paint the tunel of the hull. probably black or dark grey have not decided yet.
        I should have weighed the hull before and after oh well it didn't add an overly large amout of weight.
        • Graeme
          • Jun 2010
          • 97
          comments anyone this is my first boat so it's also my first repair.
          am I going in the right direction here any concerns ?
          • Basstronics
            • 2384
            I think the wood was massive overkill.
            I have a 25" DF knock off boat, it was thin also. I never had any cracks though.
            I ended up with two layers of carbon fiber in the rear. Wont break now :)
            • BakedMopar
              No Mo Slipah
              • Sep 2009
              • 1743
              Is the new motor mount going to be mounted on the wood? Will the motor line up with the current stuffing tube or are you re doing that too.
              • Graeme
                • Jun 2010
                • 97
                Yes the motor mount will be mounted on the wood. I don't have a motor mount yet so I don't know if it will line up we'll see
