Help on motor choice please
  • Old Vetter
    • 117
    I have a 30" fiberglass tunnel hull (mfg unknown) that has a K&B converted to electric outdrive. I have a Turnigy 90amp ESC and 4S or 5S Lipos. I thought about a UL-1 motor but they are hard to find right now. Is there a better motor that won't cost an arm and leg? Thanks
  • Dangerous_Toys
    Hiding from the Ole Lady!
    • Apr 2010
    • 2539
    Ammo 36-50-2300kV Brushless In-Runner
    ? WHAT RULES?
    • BakedMopar
      No Mo Slipah
      • Sep 2009
      • 1743
      Ul-1 motors are I. Stock at kintec and tower. I don't run tunnels so I can't help youthere but I see some using the scorpion out runners as ul-1 equivalents.
      • ED66677
        • 1300
        Feigao 9XL
        Emmanuel
        • Old Vetter
          • 117
          What's the differance in performance between a L and a XL motor same diameter and KV rating?
          • hazegry
            • Jun 2010
            • 842
            the can is longer
            • Make-a-Wake
              FE Rules!
              • 6057
              Originally posted by ED66677 View Post
              Feigao 9XL
              • BakedMopar
                No Mo Slipah
                • Sep 2009
                • 1743
                Originally posted by hazegry View Post
                the can is longer
                Therefore it will eat more amps and put out more watts.
                • Jeff
                  • 233
                  Use the ul-1 or proboat. It would be spec legal for that size hull, not hard on esc or batts. Use 4s, then you can get lots of set-up and prop tips and if you decide to race some day you would have something legal. I do not understand going off in a tanget to non-racing set-ups and then asking advice like 30 guy's run the same stuff. I personally like the bj motor from pro-boat better than thee ul-1, it has more torque and a lot more forgiving on set ups. I use the x437/3 and y537/3 and when set up real loose the x440/3.
                  Jeff
                  I try and avoid paste eaters.
