someone said it would be worst but I doubt!
Mhz Mystic S turning problem
the rudder linkages look like they are straight off the servo, but come out of the transom at some extreme angles.
And you say you have changed the servo ?
are you using flexible cable?
How are you connecting the two ESC's signal wires together are they Y harnessed ?
can you run in a straight line at all with out touching the steering ?
if not it has to be servo related,if you hold the rudder and turn the tx wheel is there any slop
Try this, Put the boat in the water, Hold the sides firmly, have a friend slowly pull the trigger. watch the rudder movement and the thrust from each prop. Find out if the issue is drive line or steering"A quick temper will make a fool of you soon enough."
I was looking hard at your pictures rather deeply, Is one of your + wires removed from your Y connector either side L or R? if not you may have harmed the Rx. I want to say Rx all the way, I run the Futaba FASST systems on everything I own ( currently trying to hook the wife up to one ) And I think they are the BEST! But one wrong move and the Rx is junk.... Also have you ever got the Rx wet? Does it hold it's bind to your Tx? I have pluged the backward for one sec and it was junk, barely got one wet and it was junk, one would'nt hold it's bind and caused the boat (SV27) to dive straight down under water..
I may be wrong but I suggest you try a new Rx.OK, You Go First!!!
tuslow,did you keep the rx that you plugged power up to back to front.
it should have a reverse power protection circuit,that will burn out and save the rest of the rx.
i did the same on one of my spektrum rx,s.the parts worth about $1 and takes about 5 min to replace
I have about 5 of them all nicely tucked away, I keep lying to myself saying I'm going to send them in for repair tomorrow but insted for every new project I run out and drop $90 bucks for another one..... Just call me Retarded!!!OK, You Go First!!!
tell you what... if the rudder or linkage are the cause of the issue... remove the rudder blade and see if it's better!... I'm not joking!
great idea, that will tell you for sure
I was actually planning to try this. But I have tried to hold the boat while my brother pushed the throttle and I could not see anything wrong.Originally posted by ED66677 View Posttell you what... if the rudder or linkage are the cause of the issue... remove the rudder blade and see if it's better!... I'm not joking!
