Are these Motors any good?
  • NOZ69R
    • Apr 2010
    • 42
    Has anyone used these style motors like this one?
    Brushless motor Model SeaMonster-3650-2300Kv
    Rotational Speed 2300Kv (rpm/v)
    Max Current 60A
    Power (W) 800W
    Input Voltage 7.4v- 18.5v
    Motor Weight 290g
    Motor Weight 310g
    Max. Efficiency 98%
    No Load Current 1.8A
    Internal Resistance 19m Ω
    Motor Dimensions (Diameter x Length) 43mm x 63 mm + 10mm(Pipe)
    Shaft Dimensions (Diameter x Length) 4.0mm x 15mm
    Input Battery Types NiCd/ Nimh/ Li-po Battery
    Cooling Type Water Cool
    Wire Winds 6
    Recommend Model RC Model Boat
    Thinking of one as a replacement for my Apparition and for only $25 I could be tempted
    Cheers
    The older I get the BETTER I was..
  • Diesel6401
    Memento Vivere
    • 4391
    Never used that motor, at 3650 it might be on the small side for a apparition though. It would be working very hard in a 30"+ cat. Try a 540xl type motor or the leopard 4074. Actually a leopard in that hull of yours on 4s might rip.
    I have a XL motor for sale in the swap shop http://forums.offshoreelectrics.com/...620#post207620
    - Diesel's Youtube
    - Diesel's Fleet
    • crystalclearvisual
      Andrew Shepherd
      • 31
      Can you get a 74mm motor in the hull
      Andy Shepherd
      • 785boats
        Wet Track Racing
        • 3423
        Hi crystalcearvisual.
        Yep. I've had the 8Xl in mine pushing it to over 50mph on an X440/3 prop with 4s.
        NOZ69R
        I think you'll find that diesel is right. The 50mm motors are a bit small for a cat this size.
        Cheers.
        Paul.
          • 6057
          NOZ69R,
          here's a 56mm version of the motor you posted, this would be good on 4s if you are wanting to go the bargain route.
          http://cgi.ebay.com/EC-Boat-RC-Outru...item3f098115dd
