NEU 1512 1,5Y vs TENSHOCK 2240/8 ?
  • Alfa Spirit
    • 2183
    Those motors are very similar: 1850kV for the NEU and 1900kV for the TENSHOCK, same weight 280 grammes (9,9oz), 2000 watts max power for the NEU and 2200 watts for the TENSHOCK and same dimensions for those motors. NEU is a 4 poles and TENSHOCK is a 6 poles motor
    Can you help me ??
  • Make-a-Wake
    FE Rules!
    • 6057
    Actually, i believe the Tenshock is 38mm dia. and the Neu is 40mm dia..............
    • Alfa Spirit
      • 2183
      Neu = 39mm and Tenshock = 38mm
      • Make-a-Wake
        FE Rules!
        • 6057
        Closer to 40mm...........39.624
        • Alfa Spirit
          • 2183
          If you want... For me that' s the same.
          I asked to Steven for 2 x NEU 1512 1,5Y 1850kV
          • m4a1usr
            Fast Electric Addict
            • 2036
            Can you help me ??
            What are you asking exactly? Which in opinion is the better motor? Details of the Tenshock motor construction would need to be known. Tough question to answer without enough information. One would need to know the quality of the iron and if they use the same thickness lamination plates. The quality of the rotors materials and construction. Knowing the IO could be the first indicator. I am out of the country and logged on to a public computer so I have few search function options. Compare the motor data from each and see if they share values or a approximate. The difference in a 6 pole motor over a 4 pole motor is not much.
            John
            Change is the one Constant
