Polyquest 30c 6s 5000mah problems
  • JMSCARD
    • Mar 2010
    • 4174
    So I have (2) polyquests that I bought used off a highly regarded member... they only had 8 runs on each... they were fine when I bought them and all had equal voltage and charged up right when I first got them... soon after when I knew I wouldn't use them for awhile I brought them down to storage level and stored them in a cool dry place... 65 degrees F.......
    Now a couple months later I go to charge them up and on both packs one cell wont charge up above 3.95 volts.... is this pack (or should I say cell) junk... or will it work its way back... I tried running one and the LVC kicked in in a hurry because of the one cell?
    My question is should I keep trying to bring it back or should I make it into a couple 5s packs, and how would I go about doing so without hurting myself or burning down the house...LOL... thanks in advance.
  • tth
    • Apr 2008
    • 1600
    If its worth it too you send them to me. I can convert them for you. Remove the bad cell and configure the balance tap to 5s. I have done it several times on my own packs. I had to do a few packs right off the back on that last batch that I got from Ray Fuller. 4 packs had a total of 5 bad cells. Go Figure!!!
    • JMSCARD
      • Mar 2010
      • 4174
      Oh yes tracy its worth it... how many dollars to have you do this...? they don't have much for use on them either.... they were mike martins packs and I can attest they checked out fine when I first got them.... SO you don't think they will come back into it?
      • tth
        • Apr 2008
        • 1600
        Honestly I cant tell you if they will revive or not. All you have to do is pay for postage to and from. I'll do the work for a fellow member for free.
        • JMSCARD
          • Mar 2010
          • 4174
          Ya know tracy you are a class act.... I'm gonna try running em one more time... if they don't accept the charge after this next try I will ship em out! And again... I will check on your label and get back to you later when I get home on it....
          • tth
            • Apr 2008
            • 1600
            Anytime...... I don't mind.
