proformance increase by setting timing
  • bea5017
    • Aug 2009
    • 173
    what kind of proformance increase should i expect by changing the timing on my aquastar to high for my3026 1900 kv on 5s or would auto timing detect do this for me?
  • alvinsmith75
    • 635
    Not familiar with your esc at all but I can promise you will make more heat than power by increasing timing.
    • Jeff Wohlt
      • 2740
      No, you can gain more power and run better depending on the motor and poles.
      You can look this up under Jay Turner's posts.
      I run all my XLs at 7 now.
      www.rcraceboat.com
      jwohlt5362@yahoo.com
      • bea5017
        • Aug 2009
        • 173
        fromwhat i understand my 6 pole outrunners need high timin approx 20 degrees?question is willl autotimingselect do this for me or do i need to program my aquastars?
        • ozzie-crawl
          • Sep 2008
          • 2943
          is your 3026 1900kv a scorpion ? if so i would run around 15 deg
          worked well on my tunnel hull
          • Jeff Wohlt
            • 2740
            Outrunners need more as he said above. Innrunners do not.
            www.rcraceboat.com
            • bea5017
              • Aug 2009
              • 173
              yeah there scorpions i got twins in my cat on 5s. so there will be a noticiblt increase in speed? 2% ? 5%? 10% ? jus curious
              ozzie what speeds ur tunnel? amps?
              • ozzie-crawl
                • Sep 2008
                • 2943
                i have no idea of what performance gain you will get if any,to many variables.
