motor selection for small rigger
  • adamb
    • 120
    My current project is a dumas lil rascal. Its a 22" long rigger and it was meant for gas but I'd like to make it an FE sport boat. What kind of motor should I be looking for? Hoping to run it on 2s. Would a 380 be enough or would a 540 class motor do it? http://www.dumasestore.com/catalog/p...roducts_id=407
    BBY Scat Cat 26 8xl &sword fish 120
    Vac-U-Cracker 20turn brushed car motor
    Dumas Lil Rascal 7L!
  • BakedMopar
    No Mo Slipah
    • Sep 2009
    • 1743
    A buddy of mine uses a 380 in a 22" scratch build rigger. I beleive he runs a 6l on 2s with a x430. The 380 cans are easier to fit in the narrow tub. I have an 380 8l in the swap shop. I used to use it in a 17.5" hydro and she was decently fast with cool temps.
    • Simon.O.
      • 1611
      For a 22"tub rigger I would suggest a 540-S motor, a 380-XL should do the job as well and it may depend on what you have and how much room you have.
      A long can 380 with a good water jacket will take up as much vertical room as a 540 short with jacket.
      I have a 22"tub rigger with a 540-7S 5000kv Fiegao motor running 2S. The pack is a Turnigy 5000 mAh 30C to a 100 mystery esc and runs a octura x632 prop.
      I have once run this as a 3S setup with a 432 prop and that was not the most clever thing I have done.
      My thoughts for a 22" tub rigger are to run a 1/8" shaft and set the motor to provide 30krpm minimum and then use a 432 and maybe a 632. I am still tyrying to get hold of a higher pitch low dia prop.
      Just some ideas
        The Dumas Lil' Rascal is a heavy boat, I'd suggest a 540 rather than a 380 motor. It will run faster and cooler with the larger prop a 540 can turn. An 8S Feigao turning an x438 should work well. I'm afraid that a 32mm prop may be too small for best performance.
          The Dumas Lil' Rascal is a heavy boat, I'd suggest a 540 rather than a 380 motor. It will run faster and cooler with the larger prop a 540 can turn. An 8L Feigao turning an x438 to an m440 should work well. I'm afraid that a 32mm prop may be too small for best performance with this hull.
          • adamb
            • 120
            Thanks for the help guys. I think a 540s or L may be the ticket. I gotta wait til its built to see exactly how much room I have.
            • Dangerous_Toys
              Hiding from the Ole Lady!
              • Apr 2010
              • 2539
              What speeds are you getting on that setup?
              ? WHAT RULES?
              • Simon.O.
                • 1611
                About 80 kmh or 50 mph.
                I once ran it with a good 3S pack and got 101kmh or 62 mph (police radar) That was not a wise move with that hull as one glitch would have cost me the lot.
