mhz z drives
  • RIPFENCE
    • Sep 2009
    • 1577
    mhz z drives
    hi all,
    do any of you have any testing/experience with the z drives sold on mhz usa..if i am reading it correctly it has a gearbox inside which can give you 16% more rpm at the prop?!?! i want to put one on my df sniper with a 2230 1y...on 12s lipo..in theory the 2230 would be turning 32000 unloaded rpms but with the z drive i could be spinning closer to 40000!!!!...am i making sense here or is this not how it would work...to gain rpm without gaining heat/amp draw is incredible...these drives look sweet..maybe some of you bigger scale guys can shed some light on these and clarify my confusion
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
  • Gerwin Brommer
    • Dec 2008
    • 928
    Indeed, the gearset inside the drive increases the rpm's by 16%
    However this does NOT mean you get "free" rpms without heat/amp draw.
    You have to do the maths with this drive, decrease the propdia !
    You should not use the same prop as if you are running a direct-drive setup !
    • RIPFENCE
      • Sep 2009
      • 1577
      sorry i am in the wrong section here...whats the real advantage here..maybe a lot smoother drive line?
      • Gerwin Brommer
        • Dec 2008
        • 928
        Most of all : the looks.
        It's a "scale-drive"
        • RIPFENCE
          • Sep 2009
          • 1577
          10-4 thanks gerwin..maybe i should stick with my reliable 40 dollar speedmaster instead...they are very nice pieces though
