Hobbycity/Joysway "Sea Fire" Hydro
  • Doozie870
    • 970
    Took the plunge and ordered one of these. Time to get my feet wet once again! She came in this morning, and I was pleasantly surprised with the hull quality and rigidness, everything seems laid out well with easy access to the components. I will be using 2 4S 2200mah in parallel for now (from my airplane stash), they just fit under the hatch. RTR trim weighs in a 4 1/4 pounds. The stock props are plastic junk, no turn fin on a hydro? and I have suspicion of the motor coupler trueness. But for the price it has room for a few upgrades as needed. Hoping for a maiden on sunday.
  • Alexgar
    • Aug 2009
    • 3701
    is it fiberglass
    • JimClark
      • 5913
      Is that a zip tie that holds the servo in place?
      Billy Graham
      • adamb
        • 120
        How much was it? Looks neat!
        BBY Scat Cat 26 8xl &sword fish 120
        Vac-U-Cracker 20turn brushed car motor
        Dumas Lil Rascal 7L!
        • Alexgar
          • Aug 2009
          • 3701
          i think there like 150$
          • Doozie870
            • 970
            Not sure what the hull is really lol, it appears to be epoxy glass with some very hard paint and possibly some carbon fiber flooring.
            The servo has a zip tie have not looked underneath it yet.
            Price was $159.99
            • ozzie-crawl
              • Sep 2008
              • 2943
              think there fibreglass reinforced plastic
              a mate had one with a blackjack motor on 6s big prop
              pulled wheelies on demand
              • Jeepers
                • May 2007
                • 2050
                that was an expensive zip tie!
                good to see you on the forums again James, you gonna come down and run with us a couple of times?
                • electric
                  • 1973
                  Let us know how it runs. The motor looks the same as a Surge boat that I have. It did around 37mph when I tested it. Could we get a picture of the back and underside?
                  • blackcat26
                    High Speed Junkie
                    • Sep 2009
                    • 1750
                    All of the sea fires I have had have been accidental!
                    • electric
                      • 1973
                      I was wondering how a 'glassed' boat could look so much like plastic. Duh. they just glassed the inside of a plastic boat. hmm. Not completely sure this is correct, but it very well may be. I am going to take a closer look.
                      • Doozie870
                        • 970
                        Hey Sean how have you been? Ill try to stop in next time Im over that way.
                        @ electric, sure will take a few tonight.
                        Whatever the outer coating is, it can chip off reveiling what I would sware is epoxy glass, anyhoo its strong and light.
                        The original motor coupler is pitifull not even close to being bored straight. I replaced it with a modified OE one, much better now. This thing has a huge 5mm flex cable lol.
                        A few pics of the servo mount.
                        • Doozie870
                          • 970
                          Bottom side and a homeade parallel connector. Off to the lake!
                          • v-spec
                            • Jun 2009
                            • 1046
                            The rudder looks so thick in the pic! Those connectors are pretty huge too!! Hope all goes well at the lake!
                            • Doozie870
                              • 970
                              Its just sorry camera phone pics.
                              Well had a successfull maiden today! It sure felt good to be on the H2O again. All went very well, aside from the flex shaft pumping in water, big time.. This must be addressed. Everything came in luke warm to the touch so Im pretty confident more prop can be safely used . The original plastic crapper appears to be in the 40-42mm range, so Im gonna try a P215 and a P220 after they are bored out to fit the odd ball shaft size. Not sure how I missed the sticker before, but the motor is a 36x56x2000kv.
                              Like a dummy I forgot the tools.. The strut needs some adjusting and the cog needs to be played with. Also the hatch is not the easiest to tape but it works.
                              Heres a couple quick camera phone vids with the stock prop.
