One cool lookin' cat!
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    #91
    Originally posted by 6S HYDRO View Post
    lets see some vid
    Yeah, I really need to get some. Working on a way to conveniently do the recording myself and have it turn out well. Think I'll try the tri-pod next.
    Rainy day today.
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3784
      #92
      Managed to get a run in while running some errands... Ran it to the LVC at 6 minutes and 34 seconds. Top speed 43.5mph.
      Using two 3s 5000mah 25c packs in series. They are old and abused Blue Lipo packs too. They were hot and puffed a bit at the end of the run...
      I'm pleasantly surprised with how well this hull handles. I'm actually starting to enjoy it. =)
      • 6S HYDRO
        • 1325
        #93
        Running that long and to you hit lvc youll puff almost any battery
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3784
          #94
          Yeah, that is quite a bit of run time and heat. I think it would do better with 2p for that kind of run time.
          • 6S HYDRO
            • 1325
            #95
            You will still have the heat in the motor and esc with 2p and prob more cause of the extra weight,
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3784
              #96
              Yep. Right now the ESC and motor are doing well. The ESC is surprisingly cool at the end of the run.
              • 6S HYDRO
                • 1325
                #97
                whats the temp on the motor
                • FighterCat57
                  "The" Fighter Cat
                  • Apr 2010
                  • 3784
                  #98
                  It's about 120 - 130 after 6 minutes. Quite surprisingly the ESC is less.
                  • 6S HYDRO
                    • 1325
                    #99
                    is that off the cooler or the endbell
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3784
                      #100
                      Good question. It is off of the tail of the motor behind the cooling can. The end bell is a little warmer. 135-ish, sometimes as high as 140.
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3784
                        #101
                        OK, she's wired up with 4 3s 3k 30c packs in S/P (6s2p 30c 6k)
                        We'll see how it goes!
                        • FighterCat57
                          "The" Fighter Cat
                          • Apr 2010
                          • 3784
                          #102
                          Motor temp went up, speed went up as well. 43.5mph, motor temp was 140ish on the end bell.
                          I'm really not sure the motor can handle any more prop.
                          I might try another motor... Like a Typhoon 500. Would be a good comparison.
                          Overall, not bad for a cheapie.
                          • FighterCat57
                            "The" Fighter Cat
                            • Apr 2010
                            • 3784
                            #103
                            Typhoon 500 = too small. May try a Typhoon 600, but going to have to research the watt ratings on the KD3674 vs. the 600.
                            I added a cap to the ESC; 4700uF 30VDC compliments of Nichicon.
                              No comparison, trust me.... h600 is 3000W 1400kv
                              http://www.hobbycity.com/hobbyking/s...0_Heli_(1400kv)
                              The typhoon 600 is crap. Burnt out first run on 4S....
                              • FighterCat57
                                "The" Fighter Cat
                                • Apr 2010
                                • 3784
                                #105
                                Wish it was a 5mm shaft.
