Some time ago there was an available flexible shaft hex driver to get to those hard-to-reach motor mount screws. Any links ? [ need a 2.5mm specifically]
Where can I find a flexible shaft hex driver ?
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoTags: None
I remember OSE carried them for awhile but I think there was an issue with inproper useage and them breaking because of strong arming them. You can always use what I use Tony. Cut a 1/2" section off an allen and slip it into a 4 or 5" section of small silicone tubing. It will allow you to rotate it off angle and get those hard to reach motor screws!
JohnChange is the one Constant
Brilliant ! Thanks JohnOriginally posted by m4a1usr View PostI remember OSE carried them for awhile but I think there was an issue with inproper useage and them breaking because of strong arming them. You can always use what I use Tony. Cut a 1/2" section off an allen and slip it into a 4 or 5" section of small silicone tubing. It will allow you to rotate it off angle and get those hard to reach motor screws!
John
[ as a reward for your suggestion, here's my secret stuff for holding small screws to a tool for locating tight places ] - just a microdot on the tool tip & holds 'till the fastener is seated
Last edited by properchopper; 07-08-2010, 01:37 PM.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Nice idea... While we are sharing I have one also USE CAUTION..
take a screwdriver, get a length of 10 or 8 ga wire and coil it around the shank of the screwdriver.. Touch one end of the wire onto the + terminal of a car battery and just strike the other end of the wire across the - terminal a few times BEING CAREFUL NOT TO SHORT FOR MORE THAN 1 SEC AT A TIME ( best to use an old or someone elses battery
thats not currently in a car)
Your screwdriver is now magnetic..
lol...yup it was the "cool tool" and I ended up strong arming mine till it was useless.....steve gave me a refundOriginally posted by m4a1usr View PostI remember OSE carried them for awhile but I think there was an issue with inproper useage and them breaking because of strong arming them. JohnSPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
How 'bout this ?Originally posted by crabstick View PostNice idea... While we are sharing I have one also USE CAUTION..
Yeah I got one of those suckers too, except mine has a slot for demagnetizing also
Still, I find the coil method gives a stronger magnetic field and plus the sparks make it all the more exciting
Grab a hex key, driver and flex cable of your choice and braze together.
I have an old flex cable... maybe I'll make one up if I get the chance. Cool tool to have.
Home Depot had a flex drive set and Harbor Freight had a little flex drive set too. I think All-Spec has a flex kit too. http://www.all-spec.com/products/SPT8000-A.htmlFighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
I'm primarily concerned with getting the screws seated. I'll torque them down/break them loose with the "L" shaped wrench.Originally posted by Alexgar View Postat one time i found a hex driver on a flex brazed across it, but there out there, as far as torque i dont know2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
