well after seeing all the fuss about wether scuffing the boats bottom will make you go faster some guy's swear on it but yet i do not get this if it works then why do guy's?polish there props wondn't if you wet sand them fully dull a layer of water will stick to the props surfaces( like on the hulls bottom when scuffed) thus making the prop spin faster because it will cut through the water easy because water on water is slipereir than a shiny surface is? if it works on the hull it should do the same on the prop...so why does everyone polish the props.... why not polish your hulls bottoms then?
..,Albert
