Mono Rudder Placement - Why the Offset??
  • tharmer
    • 342
    Seems the Unlimited Hydros (who turn left) have the rudder on both sides. I think that having the rudder on the inside would make it more likely to leave the water if the boat lifts the inside sponson.
    -t
    • FastVee
      • 649
      Need help with my 57" apache project.
      Will have twin motors and struts. -But I want to use only one rudder and put it to the center of the transom
      It will be for sport/wave bashing, not racing.
      So would it work?
      -Can the rudder be closer then struts to transom?
      Rudder size? -this too big?
      CMSimple is a simple content management system for smart maintainance of small commercial or private sites. It is simple - small - smart! It is Free Software licensed under AGPL
      with this adapter it is about 2" from transom
      Please reply, need to order parts soon!
      -Pate
      www.youtube.com/rangerpate
      • Rumdog
        • 6453
        You'll probably want to use a standoff to get the centered rudder behind the props.
        • AlanN
          • Mar 2008
          • 334
          So would it work?
          -Pate
          The rudder blade should not be closer to the transom than the struts. The rudder blade should be a as far from the transom as the props or slightly farther back. For one thing you don't want to disturb the water that the props will eventually see. The other issue is leverage.
          ps make sure the rudder swing clears the prop diameters!
          • MarkF
            dinogylipos.com
            • Mar 2008
            • 979
            On my cybersorm I have the rudder in the center and it works just fine for running fast and strait. My 2 records in Q mono and Offshore are with this boat. Now for oval racing I don't think its better in the middle. I would prefer it offset to the right for that. Now having said that I did set this boat up for my girlfriend with a mild motor so that she could turn it in both directions. Thats why I put the rudder in the middle and a turn fin on both sides. I took a shot with this boat running it at the saw events set up like it is and was very happy with the results.
            Mark
              • 5554
              On all my early builds i used a center rudder cuz i thought it looked better.......turns out, they work great........turns are very good both ways. My first were BL Villains and then a 45" Dumas..........the Villains turn on a Dime! I think it works just fine......................
              Blue Villain was before the pearl blue paintjob.....
              • FastVee
                • 649
                editff topic
                • T Nissen
                  Newbie all over again
                  • Feb 2010
                  • 46
                  ...With most monos the placement to the right works fine for turning either direction, I know my Aeromarine Titan 40 turns very well in both directions, but its rudder is long enough to stay in the water during a left turn..
                  Jay, do recommend offsetting the rudder to the right in an offshore mono then (as long as you use a longer blade)?
                  I am planning on building a P Offshore (DF29) for the Limited class and was wondering. Good question Darin.
                    • 7990
                    Because the boat turns better to the right with an offset rudder, and because you have a lot more right turns on an offshore course than left turns, a right-mounted rudder works fine. You will have to put a turn fin on the left corner of the transom - most put a smaller fin there than on the right but do what works on your hull. I've watched plenty of gas monos run the offshore courses with a right side rudder and win...
                    • properchopper
                      rcgoatbuild@snotmail.com
                      • 6958
                      DF 33 clone; offset rudder ( SPD .21 rudder trimmed 3/8" - homemade reinforced bracket)
                      W.O.T. U-turns right & left:
                      • T Nissen
                        • Feb 2010
                        • 46
                        Thanks Jay!
