Stuffing Tube Question: 0.187" flex in 1/4"
  • Shooter
    Team Mojo
    • Jun 2009
    • 2520
    Has anyone ran 0.187 flex in 1/4" stuffing tube (no liner)?? There's a bit of slop and I'm worried it won't be supported radially. I've considered a 7/32" tube, but heard horror stories of overheating.
    I've also hear horror stories of the stuffing tube "flarring out" at the motor end with 1/4" (too much slop).
    Anyone have experience with this? Thanks!
  • BakedMopar
    No Mo Slipah
    • Sep 2009
    • 1679
    I run that setup no issues. A 3/16" cable in a 7/32" tube is really tight. This is run with a 1521, 48mm prop in a mono that weighs 9+ pounds.
    • Shooter
      Team Mojo
      • Jun 2009
      • 2520
      That's exactly the answer I was looking for. Thanks. Do you get any water in your hull from the gap? I'm assuming the tighter strut bushing fit and the fact that the windings tend to pump the water OUT as opposed to IN should help. Just curious...
      • RaceMechaniX
        • 2825
        The size is correct. To prevent leakage you can use a piece of fuel tubing over the motor end, but make sure it is not dragging too much on the shaft. Shrink tubing also works or just keep it greased.
        Tyler Garrard
        NAMBA 639/IMPBA 20525
        T-Hydro @ 142.94mph former WR
        • BakedMopar
          No Mo Slipah
          • Sep 2009
          • 1679
          I get no water through the stuffing tube without and tubing etc. Just keep you shaft well greased and you should be fine.
          • c_michael_72
            • Oct 2011
            • 184
            It's been reccomended to me to use the same 3/16" flex direct in a 1/4" tube with no liner. This is for a 36" Cat, Leopard 4092 1730kv, 6s. I'm concerned with wear/maintenance as I've always used teflon, which clearly is simple and inexpensive to replace. Will the 1/4" tube last if setup properly? It would suck to have to uninstall a custom glued and bent 1/4" brass stuffing tube on even an anual basis. Do I have this all wrong?
            • longballlumber
              • 3119
              Yes and Yes
              3/16" flex in a 1/4" brass stuffing tube with NO liner will last longer than the life of the boat (assuming you properly grease the cable and often as necessary).
              Later,
              Mike
              • TINY
                • Aug 2011
                • 176
                Originally posted by longballlumber View Post
                Yes and Yes
                Later,
                Mike
                most of my oval are as above... Re grease every race... Teflon is a toy and great for eggs on your frypan..
                • longballlumber
                  • 3119
                  Hey Pete,
                  You have the right stuffing tube spec’d out. I am not sure what your putting this in, but I would suggest putting an "S" bend into your stuffing tube rather than the "J" style bend that seems to be more popular in the FE world. The S bend can be slight and is what goes into ALL of my boats. In my mind and opinion; at full song, the flex is trying to straighten out. An S bend is going to support the flex at 2 points. To me that supports the flex better than the J style bend. You've seem my stuff run. The proof is in the pudding...
                  Another thing to think about is gluing the next size tube into the hull (9/32" brass tubing I think) into the hull and uses that to sleeve the ¼” shaft. That way if the ¼” shaft ever gets damaged you can replace it with out ungluing the 9/32” tube. I have used this method in my P-Limited Sport Hydro (the orange one), my recent Q sport build, and my new .21 rigger. It works!
                  Later,
                  Mike
                  • c_michael_72
                    • Oct 2011
                    • 184
                    Mike,
                    Many thanks!
                    Chris
                    • Steven Vaccaro
                      Administrator
                      • 8724
                      Later,
                      Mike
                      thats the way I do it on my personal boats. Makes changing the stuffing tube easier. I've found with the s bend you will need a shorter 9/32 tube.
                      Steven Vaccaro
                      • c_michael_72
                        • Oct 2011
                        • 184
                        A quick search yeilded two similar hardware based alternatives to glassing in a tube.
