push rod seals
  • JimClark
    • 5913
    push rod seals
    Looking for small pushrod seals. I have some real small ones that fit into a .250 hole but just not big enough to allow for the rudder travel I want on my Micro Hydro. I was wondering if anyone can tell me the size of tube these Etti 2mm seals will fit over?
    http://www.etti.com.hk/product_info.php?products_id=88
    Jim
    Billy Graham
  • NativePaul
    Greased Weasel
    • 2770
    I have not bought them from ETTI but I regularly use what looks to be the same bellows from a different distributer, the end has a grommet built in so I mount them direct to a 7mm hole bored in the hull easier lighter and works perfectly, if you want to mount them over a tube I think stretching them over a 7mm tube would be your best bet for a good seal, although with a cable/zip tie it should seal round a 6mm tube, I don't seem to have one knocking around that isnt glued into a boat to test it out though.
    • bigwaveohs
      • 606
      I've been looking into seals for our latest project and have some of these but they are too small to use for rudder pushrod; they don't allow proper lateral motion due to the 7mm size.
      I'm going to try the Aquacraft radio box seals...about 3/8" diameter...Tower and others sell them for $2.70 a pair.
      I let the dogs out...
      • sailr
        • 7128
        We have them. $1 each.
        Mini Cat Racing USA
        www.minicatracingusa.com
        • Shooter
          Team Mojo
          • Jun 2009
          • 2752
          The ones that Sailr posted above work great for tight spaces. This is probably WAY over-kill, but I usually turn an aluminum plug and place an o-ring over the seal. It fits real nice in the groove on both the seal and the plug. If you're interested, I can send dimensions for the plug.
