Genesis cat,,,
  • HYDROJERRY
    • Jan 2010
    • 2709
    #76
    Keep it going guys i need to no all i can about this boat, im going run it stock for now after i figure out the stupid programing on the esc,, i hate this part..
    • simo71
      • May 2010
      • 74
      #77
      You have the Turnigy speed control yes? get the program card....easy as then.
      • HYDROJERRY
        • Jan 2010
        • 2709
        #78
        Its a HOBBYwING....
        • simo71
          • May 2010
          • 74
          #79
          Same ESC, both are the seaking...will use the same program box/card.
          • Alfa Spirit
            • 2183
            #80
            Great GENESIS from ASTEC, the motor is a FSD 540XL
            • sailr
              • Nov 2007
              • 7128
              #81
              Nobody in the states is going to stock these because by the time we add shipping, our COST is the same as Hobbyking is selling them to YOU for.
              Originally posted by johnf View Post
              Looks great HJ! Wish someone in the states stocked these. It's a killer looking hull.
              Mini Cat Racing USA
              www.minicatracingusa.com
              • HYDROJERRY
                • Jan 2010
                • 2709
                #82
                OK can you recomend one, i see many different ones and where to get it fast..
                Thanks Alfa,,,
                • sailr
                  • Nov 2007
                  • 7128
                  #83
                  Myself and a fellow club member have had VERY bad luck with the 580 motor! When it goes, it takes out the esc too! After a total of 4 motors and 4 esc's between us, the NEU motor became the CHEAP solution!
                  Prop the 580 WAY down from what you would normally expect!
                  Originally posted by Rumdog View Post
                  Run the 580. Be careful, do not overprop it! Many, including myself have had bad luck with that motor. Or, sell them all and get a Neu.
                  Mini Cat Racing USA
                  • johnf
                    • Dec 2009
                    • 1086
                    #84
                    Yeah Jim, its unfortunate, but I remember reading that. I'd be willing to pay more to a local dealer if they took the time to tweak out some of the issues. Unfortunately it would probably drive the costs up too much to be worth it.
                    Catching Air!
                    • Diesel6401
                      Memento Vivere
                      • 4391
                      #85
                      Thanks Alfa,,,
                      http://www.kintecracing.com/Electrical.html scroll down
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • Diesel6401
                        Memento Vivere
                        • 4391
                        #86
                        x642, m445, cf48, those are props I was thinking bout using. What do you think or should I grab something else?
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • sailr
                          • Nov 2007
                          • 7128
                          #87
                          I think I may have misled you. I thought you had a Feigao 580 but after going back to earlier in the thread you said a Feigao 11XL, that is just the 540 Feigao. Nowhere near the worries with that motor. Sorry if I scared you!.
                          With the 11xl having a KV of 1557, I would start with the X642. The M prop is more suited for a hydro or rigger. Watch your temps. You should be fine.
                          Mini Cat Racing USA
                          • Alfa Spirit
                            • 2183
                            #88
                            • Diesel6401
                              Memento Vivere
                              • 4391
                              #89
                              No you were right. I have both motors a 580 7l and a 540 11xl. So you think the 11xl would be better than the 580 7l? What if I used the 580 7l with a x642? I'm just confused on what would be the best option
                              - Diesel's Youtube
                              - Diesel's Fleet
                              • Alfa Spirit
                                • 2183
                                #90
                                Use the 580L but 8Turns will be better with 6S
