Help with my scratch build CG
  • F1 madness
    • Feb 2010
    • 788
    Im having a little difficulty working out my CG,on my new build.
    Its a 37"mono hull that iv designed and built (my 1st mono build)
    If you could have a look for me and see what you reckon would be gratefull
    http://forums.offshoreelectrics.com/...ad.php?t=15627
    Thanks F1
    http://s577.photobucket.com/albums/s...79/F1%20boats/
    Daz from sunny England
    Most monos run best with the CG between 25% and 30%. The optimum placement depends on the amount of total lift in the hull ( areo and hydro) balanced with the speed and total weight. Make the CG adjustable between these limits and you should be golden.
    I'm afraid that the Scorpion S-3020-12 motor is on the small side for a 37" boat. It lacks the torque to spin a very large prop, and a 38mm prop won't push that big hull very well. I run an HK4025/6 on 6S1P in my 34.5" cat and get 45-50 mph with an x455 prop.
    Regardless, that's a nice build!
    • F1 madness
      • Feb 2010
      • 788
      cheers bud,im working on it now trying to fit everthing in as is tight due to the height,a little whoopsie on my part but will get their,was just srtuggling to get the cg and being my 1st mono wasnt sure were would be best to start with but can carry on now.
      iv got a 540L 1800 but will only take up to 5s,due you think its worth trying that instead then on 4s
      • F1 madness
        • Feb 2010
        • 788
        Took a couple of pics and worked out CG:29%
        Pic of CG:28%
        Which do you think will work best?
        Just trying to work out to move rudder starboard side
          Tough call on the motor, neither are optimal. I'd start with the 6S setup and a 42mm prop, run for just one minute ( use a stopwatch!) and then bring it in and check for heat.
          • F1 madness
            • Feb 2010
            • 788
            Im just hunting around for a new motor and seen this:
            Scorpion HK-3026-1400KV
            Specifications
            Stator Diameter 30.0 mm (1.181 in)
            Stator Thickness 26.0 mm (1.024 in)
            No. of Stator Arms 12
            Magnet Poles 10
            Motor Wind 6 Turn Delta
            Motor Wire 24-Strand 0.25mm (AWG)
            Motor Kv 1400Kv RPM / Volt
            No-Load Current(Io/10V) 3.33 Amps
            Motor Resistance (Rm) 0.010 Ohms
            Max Continuous Current 80 Amps
            Max Continuous Power 1680 Watts
            Weight 199 Grams (7.02 oz)
            Outside Diameter 37.50 mm (1.476 in)
            Shaft Diameter 4.98 mm (0.196 in)
            Body Length 48.4 mm (1.906 in)
            Overall Shaft Length 74.2 mm (2.921 in)
            Max Lipo Cell 6s
            Do you think this will be anygood.
            Im relativly new to brushless & lipos so just trying to see what would work best.
            • F1 madness
              • Feb 2010
              • 788
              Alrite bud struggling to decide what set up would be best,which 1 would you say,im trying to take into prop-torque and balance and trying to keep everything as low as possible.
              this 1 or 1 of the other 2 in post above.
              really apreciate your help mate cheers
