Setup for Genesis cat Twin ??
  • Alfa Spirit
    • 2183
    Hello guys, what batteries for a twin setup? 4S, 5S or 6S per motor?
    Here is a link to HPR 06 (115cm) setups, Genesis hull is 100cm. Thanks
    DropCatch.com helps you secure expiring domain names.
  • BakedMopar
    No Mo Slipah
    • Sep 2009
    • 1743
    I think it all depends on you wallet.
    • Alfa Spirit
      • 2183
      My wallet? No
      My question is 2x4S enough or is 2x6S too much for the Genesis ?
        • 9481
        Sweet!
        where can you buy just the hull?
        • HYDROJERRY
          • Jan 2010
          • 2709
          Think its only sold at HK but if im its sold somewhere else please tell me ,Hk always says backordered and i want one,,,
          • Alfa Spirit
            • 2183
            I' m very sorry but the Genesis hull alone isn' t available This one is a present.
            About the setup, 2x4S or 2x5S ?
            • westbeach
              OSE Rocks!
              • 969
              Alpha, do you have the motors and batteries yet? Do you have something in mind? We can help you better if you know what you want?
              If you went with the NEU 1521-1Y run it on 5S. Hope this helps.
              HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
              • Alfa Spirit
                • 2183
                I don' t have batteries and motors for that hull, I don' t want to make a mistake with wrong components.
                First I want to choose the right voltale, 2x4S or 2x5S . Thanks
                • westbeach
                  OSE Rocks!
                  • 969
                  I would go 2x5s for weight specially in a cat hull.
                  • Alfa Spirit
                    • 2183
                    Ok westbeach, 2x5S looks best choice, More advice please
                    • westbeach
                      OSE Rocks!
                      • 969
                      Motor choices and props. What hardware are you going to use?? rudder and drives?
                      What is your budget for this build? Do you have a budget? Do you want to use low end motor or quality motors?
                      • westbeach
                        OSE Rocks!
                        • 969
                        As far as motor choice go, I would go NEU 1521-1Y (1577KV) or second choice Castle
                        1520-1Y (1600KV). Props, X442, X442R and X447, X447R.
                        • Alfa Spirit
                          • 2183
                          No specific budget, I' ve got powertrims from Rc-Raceboats.de with ball bearings inside and Hopf rudder (120mm)
                          I ' ll use Neu or Tenshock motors.
                          Is 35000 RPM too high?
                          • westbeach
                            OSE Rocks!
                            • 969
                            Is that the Kv of the Tenshock motor, 35000 kv?? If it is the Kv then it is a 2S motor. Do you have a link to the tenshock motor?
                            No specific budget, I' ve got powertrims from Rc-Raceboats.de and Hopf rudder (120mm)
                            I ' ll use Neu or Tenshock motors. Is 35000 RPM too high?
                            • Alfa Spirit
                              • 2183
                              If I go for 2x5S, motor will be 1800kV or 1900kV with X442 propellers?
                              For us in France Tenshock are cheaper than Neu. Brushless Motor TS 2240 : 6 poles, very high efficiency, light weight
