hello;
I just ordered a set of these mounts for my genesis.Could you tell me how they are installed?Also,it seems like there would be a lot of weight pulling them back and down.I have tried 4 different mounts and none worked.There is not much room to install a motor mount if any.One thing I did notice about the power trims;you have to be very careful drilling the holes to mount them.They are very close together.What I did was get a small piece of 1/8" thick piece of aluminum and matched it to the back of the power trim.drilled all the holes I need then put the small pieces against the inside sponson back and install each one.This is my first twin build so I hope it all works out.At first I am using the stock motors from a genesis,along with two HK 125amp esc's opto.Also have two HK ubec that will be installed.As for batteries I am going to try 2x4cell 5000mah lipo's,after that if needed I will install 2x5 cell lipo's.I will be buying two leopard motors and try them this summer.
So how have you made out with the build of yours?Looking forward to seeing it done. Have a great day
AL
AL
