Paint remover?
  • FE Wannabe
    • Jul 2007
    • 654
    Paint remover?
    What do you guys use to remove spray paint off of a hull?
    I have bought a used BK Bandit S Cat hull that has a rough paint job. I know there is probably a nice German gel coat under that paint and I would like to see it. Is there any product that will remove paint but not harm the gel coat?
    Thanks for any help.
    Brad
    SoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150
  • Jeepers
    • May 2007
    • 2050
    sand paper!
    • westbeach
      OSE Rocks!
      • 969
      I know for a fact that oven cleaner removes paint. You should have some at home, so try it in a little corner and see what results you get.
      HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
      • FE Wannabe
        • Jul 2007
        • 654
        Thanks, I will have to give it a try in a small inconspicuous area.
        • ozboater
          • May 2007
          • 419
          i vote a second for the allmighty sandpaper
          • focused
            Dutch Electric Powerboats
            • Jul 2008
            • 237
            Try nailpolish remover , works for my boats and paint.
            • hazegry
              • Jun 2010
              • 842
              I used to do graffiti removal see if you can find a product called lift off it should do the trick try it in a small area first though.
              • FE Wannabe
                • Jul 2007
                • 654
                Thanks guys for the suggestions. I think I prefer one of the chemical based paint removers instead of sandpaper because I may have a better chance of not damaging the gelcoat below the paint, which is hopefully in decent shape.
                Brad
                • Basstronics
                  • 2384
                  Is there any more insight on this topic?
                  I got a boat I painted and messed up on. So I painted more primer, color and clear to an OK finish. However I think I added to much weight to it.
                  So I wanna go back down to the gel coat and start over.
                  Its on a 16" hydro.
                  • H2OCamel
                    FAST ELECTRIC EVERYTHING
                    • Oct 2007
                    • 494
                    well my dad tought me a mean trick to get even with not-so-nice-people.....automotive brake fluid in a squirtgun takes paint right off of a car! loose the squirtgun and just use the brake fluid and a rag. put it on let it sit a few and you can wipe the paint right off. I have used it quite a bit on abs boats with great success. I would test it on a small spot first to see it's reaction to the gell coat. washes off with soap and water or simple green works best.
                    "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
                    • Basstronics
                      • 2384
                      Dabbed brake fluid on the canopy.
                      Crossing my fingers. I got about 20 coats of paint to take off to the gel coat.
                      Never using Krylon Paint again!
                      • Alexgar
                        • Aug 2009
                        • 3701
                        brake part cleaner work for me on abs havent used on fg though
                        • LarrysDrifter
                          Big Booty Daddy
                          • May 2010
                          • 3416
                          I wonder what soda blasting will do?Its like sandblasting,but baking soda is used.I do know that it will remove the gel coat,but since its down to bare fiberglass,you can have a body shop paint it with automotive paint.
                          • Basstronics
                            • 2384
                            I had some goo gone and tried that. Nadda... It seemed to soften up the clear coat though. So I wiped the hatch down with it and got the paint gummy like. It took a finger print- so it was softened.
                            I wiped it down with brake fluid and left it sit overnight. This morning I went out and kinda scratched at it with my thumb nail. The paint (2nd paint job orange and clear) is loosened up now. By the time I get home from work a stiff plastic brush should remove the orange. Then to get the blue off...
                            • Darin Jordan
                              • 9446
                              I've had really good luck using this:
                              Darin E. Jordan - Renton, WA
