Poly rc's 30c 35c 5000 5050 are they the same
  • JMSCARD
    • Mar 2010
    • 4174
    So I just got my order from Rclipos.com.....
    They were supposed to be all 5000 mah 30c xq series poly rc packs....
    all the 5s packs came with the normal poly rc 5000 mah 30c label....
    well the 4s packs came with a ployquest 35c 5050 mah 35cc label... both are xq's..
    when I called rclipos they said they are the same packs but that the 30c 5000mah packs were downrated... so the 30c 5000mah label I'm used to seeing on all my other packs are really 5050mah 35c batts???? is this true? I am worried because I have alot of already existing 5 month old very low cycle 30c 5000mah packs already... I am trying to keep the same exact packs for obvious reasons...??? what do you think of this???
  • Gary
    • Jan 2009
    • 1104
    Dont worry Jason.....It is only label changes. When you talk to the right people about certain things you buy you find out that alot of stuff is just relabled or slightly differrent changes in labeling. Pat at RC LIPOS would NEVER be disonest to you. Hes a great guy in my book.Hope this helps.
    H&M 1/8 Miss Bud 73 mph
    Chris Craft 16 mph
    • JMSCARD
      • Mar 2010
      • 4174
      I am super happy with them at RCLIPOS.com they got right back to me and called me and I do believe them and what they are saying at rclipos just wanted a second opinion to make sure before I hooked em up in series and parrallel in a expensive setup.... they are destined for my new cat from catboi...
      • tth
        • Apr 2008
        • 1600
        You should box them up as fast as you can and send them right over to me for testing and I will get some results for you!!!!
