true like the HELP blister packs at advanced or auto zone right? I lost with what you mean by closed loop. That would recirculate the salinated water.Closed loop meaning it has sense and only runs when water is in the sytem. Is that what you mean fighter?
Water Pump?
I use a water ballon fitting on the end of my lawn hose. It tapers so I just slide the water line over it and turn the water on let it run for a few minutes.If all of your wishes are granted, many of your dreams will be destroyed!
Cool, got it.
The build your own fountain kit. Gravity fed top tank, submersible pumped bottom tank. Gravity feed the flush lines that empty into the bottom tank. That will allow me to simply change/filter the bottom tank's flush liquid. EZ enough.
Thanks guys! =)FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
