I want to get a new prop for my SV 27(Octura v940/3)<I was thinking about this.Anyway what is the difference betwen a 2 blade and a 3 blade prop.does a 3 blade help with cavitation???
3 blade prop ?
The v9xx/3 props are lifting props and do not work well on monos like the SV27. This is due to blade shape, not the number of blades. A 3-bladed prop allows a smaller diameter for less torque roll. IMO 3-bladed props are seldom a good idea for most FE boats - a 2-blade will usually do better.
If you are going from a 2-blade prop to a 3-blade prop, the rule of thumb is to get a 3-blade prop with 80% of the diameter of the 2-bladed one.
You didn't seem to read my post very well.Originally posted by kck741OK so a 3 blade will cause the hull to lift out of the water making prop walk...then why does the SV come with a 3 blade?
The number of blades has nothing to do with it, it is due to the shape of the blades....This is due to blade shape, not the number of blades....
I do not know where the V9xx series is listed for cats and monos, but it is certainly not appropriate for them. I did set records with a v937/3 on a special SAW cat, but for most cats it is a very poor choice. On monos it simply does not work. For oval racing with hydros they are okay but better props exist. For SAW racing they are awesome.
I run a Y537/3 on a 14XL with 24 cells in a Mean Machine hull. It is my favorite prop for sport running with this setup.ReddyWatts fleet photo
I read it first in Mr Reddy Watts Prop description post.I do not know where the V9xx series is listed for cats and monos
Then I remember reading it again in this octura prop directoryLink Not that I dought what you said for a second I'm just trying to point you tward where I saw it.V9 are moderate lift suitable for riggers, mono's and catLast edited by SJFE; 09-19-2007, 10:03 PM.
SJFE - I don't see the v9xx series props recommended for any boats in the link you posted...
A little history: Octura designed the v937/3 for 3.5 outboard tunnels. The prop was a failure in that application and languished for years until discovered by FE guys in about 2001.
. I thought that was the place where I saw it. Thats what I get for rushing to find a link on the way to bed:blushing:. Maybe I just wanted justifie the two finished v9xx's in my prop box so bad I believed I saw it
