When setting up your esc and motor to be water cooled, What would you cool first if you only had one water pickup and outlet?
Water Cooling
Tags: None
The water will pick up much more heat from the motor, taking much hotter water to the next item in line - the ESC or the water exit. ESC cooling is not nearly as efficient so the water is heated much less as it leaves the ESC. It maximizes the overall cooling efficiency to cool the ESC first.
? WHAT RULES?
