hydra 240 issues...
  • mschaffer66
    • Jan 2010
    • 335
    hydra 240 issues...
    My buddy has a Hydra 240 in his fastech and when he plugs in the batteries it just has a fast flashing red led...cooked esc?
  • mappo
    • Feb 2010
    • 496
    Did your buddy program the hydra for lipo cutoff voltage? if battery is set for too low a cutoff it will just blink, so reprogram.
    Do you know what the biggest problem with the world is?
    That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
    • Steven Vaccaro
      Administrator
      • 8932
      Or its not getting a signal from the receiver.
      Steven Vaccaro
      • mschaffer66
        • Jan 2010
        • 335
        Yeah it was running fine then it stopped opened hatch and it was blinking nothing was even close to warm...
        • mschaffer66
          • Jan 2010
          • 335
          It had steering though. Maybe the throttle port on rx puked?
          • sailr
            • 7128
            How many cells you running? Did you use the BEC or onboard receiver pack. I don't think you can use the BEC with over 3S. You might have cooked the BEC.
            Mini Cat Racing USA
            www.minicatracingusa.com
            • BakedMopar
              No Mo Slipah
              • Sep 2009
              • 1743
              If you had steering the bec is fine.
              • Boatman
                • 875
                experience would tell me to check my motor/esc connections and I would look into the motor more than the esc.
                • ncornacchi
                  • Jul 2009
                  • 256
                  Every now and then, I get the same problem, steering only, blinking leds, I've had to rebind receiver and then reprogram controller and then it works fine,,,happpened a few times, almost like it forgot its programming
                  • FighterCat57
                    "The" Fighter Cat
                    • Apr 2010
                    • 3784
                    Mine just sat there all retarded like that new. It looked like it was trying to arm and just dying after the first few beeps.
                    I held the throttle on the Tx, plugged in the ESC and viola, it came to life, did some funky beeping, Tx-> full break, some more funky beeping, then Tx -> 50% neutral.
                    Then unplugged- replugged and it armed, ready to go. A little odd that it doesn't make any noise or light up until it's configured.
                    • drwayne
                      • 3012
                      If it worked fine, then stopped..and the BEC still works aok.. Id suggest LVC.
                      if batts under LVC at connect, the esc will not arm ( no beeps).. a continuous flashing led suggests it's time to recharge
                      W
                      W
                      • sailr
                        • 7128
                        I have had CC controllers 'lose' the throttle endpoint settings and do the same thing. Plug in the batt, hold full throttle until you get a series of beeps. Go to full brake, another series of beeps. Now it should arm.
                        Mini Cat Racing USA
