Polishing props
  • JohnZ
    • May 2010
    • 267
    Polishing props
    What's the most common way to polish props? Polishing compound used?
    What about tumble polishing? What material is used for this?
  • teach
    • 509
    To the best of my knowledge most folks have stopped polishing.
    • m4a1usr
      Fast Electric Addict
      • 2036
      Since polishing is normaly done after sharpening and balancing I dont think you want to use a tumbler. Voodoo says this; http://www.voodoopropellers.com/polish.html
      I like to use a polishing wheel on my dremel with some car polishing compound and get it done. I only polish the one side myself. YMMV.
      John
      Change is the one Constant
      • egneg
        • 4759
        I use 400 grit wet/dry paper to finish props. It doesn't give you a mirror finish but it is just as smooth to the touch. The difference in speed would (maybe) only matter running SAW.
        Just my .02
        Chuck
        IMPBA 20481S D-12
        • JimClark
          • 5913
          sand them then brasso
          Billy Graham
          • dana
            • Mar 2010
            • 3660
            yeah i always read a polished prop cavitates more, and 400 is a good finish. It's not a mirror finish but the rough surface grabs and throws the water better. Just what i read tho, seems logical "shrug"
            • egneg
              • 4759
              I have polished plenty of props and will continue to do so if that is what folks want. The argument will probably go for ever until someone comes up with hard data to prove things one way or the other.
              IMPBA 20481S D-12
              • BakedMopar
                No Mo Slipah
                • Sep 2009
                • 1743
                I use mothers. The ones I sell I polish. Most that I use I don't.
