power supply questions
  • ozboater
    • May 2007
    • 419
    my mrc 977 superbrain power supply has crapped out for the second or third time... i m not going to bother to send it back to be repaired since it s only a matter of time till it fails again... the charger is still fine so i guess it isn t a total loss...
    anyway, i now have the 977 charger and a triton charger, both with no power supply... is there such a thing as a power supply that will power both chargers at once... i only run 2s lipos (5000mAH) and like to charge two at a time... so i guess 2 chargers running at once, charging a total of 4 lipo packs... is there any thing you guys would recommend since i m already fed up sticking my head under the hood of the car...
    cheers
    oz
  • m4a1usr
    Fast Electric Addict
    • 2036
    You can get a switching power supply off ebay. You can find a 12 to 20 amp for less then $40 delivered. Should do both chargers no problem and the power supply is well filtered. There are other choices too, not sure if they are cheaper though for the amps.
    John
    Change is the one Constant
    • j.m.
      • 847
      Convert a pc power supply!!
      I have a 350w power supply that can take a 6 amp load on the 12v lead. Go to a pc repair store and pick up a used (shouldn't be more than $20) or 'broken' (free) box. Look up online how to convert a PC power supply for rc use. It's really simple. The power supply will say how much load it can take at each voltage on a large label on the side. Look for something that will handle what you want + 3 or 4 amps. All PC power supplies have a failsafe to shutdown if overloaded so anything in the junk bin should just have missing or bad connectors.
      If you can assemble a model boat, you can convert a power supply for workbench use.
      Jon
      • lectriglide
        • 540
        This'll do ya!!
