40.160. Schulze Question
  • T.C.
    • Sep 2009
    • 245
    #61
    Yea , I,m thinking youre rite, I'm going to try and figure out why it only see's com port #3 on one program?
    Does yours show #3 on both?
    In the other program It only showes 1,4 and auto. think that could be the problem?
    If so how can I fix it?
    It has no com #3 to click on when I am in the connection part of the program.
    T.C.
    • RaceMechaniX
      • 3024
      #62
      Mine switches com ports based on which port I plug it into. On mine it shows 4.
      From your desktop screen, right click on "my computer" and select the hardware tab.
      Next open the device manager tab and expand the com port and/or USB ports in the menu. You should be able to see which port the adapter is connected to.
      Tyler
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • T.C.
        • Sep 2009
        • 245
        #63
        Doesn't matter what I do, it still comes up with either "connection error" or "please plug the controller into the computer and after that into the flight/drive battery"
        This sucks! I cant get the program to read the ESC.
        Any idea's are welcome.................?
        T.C.
        • gerardobrandao
          • Mar 2008
          • 166
          #64
          schulze interface problems
          Hello T.C
          Why just don´t you use the akkusoft instead of the future soft!?!
          HAve you already tried?it´s the same thing....
          Very Best Regards
          • SteveReesor
            • Dec 2007
            • 25
            #65
            I have tried both programs with no luck. It's the same result exactly with either.
            Steve
            Reesor Boat Works
            • T.C.
              • Sep 2009
              • 245
              #66
              Thanks for the reply Gerardobrandao,
              I still get the same "connection error" or "please plug the controller into the computer and after that into the flight/drive battery" in either program ?
              It's just not reading the ESC for some reason ?
              T.C.
              • T.C.
                • Sep 2009
                • 245
                #67
                So here it is Wed. and NO word from Schulze ?
                Has anyone gotten any information regarding this problem?
                We emailed them once last week and twice this week asking for advice on what to do to get this thing working .
                We have not been extended the courtesy of a reply, maybe they don't know?
                Wont that be great, a $600.00 I don't know?
                Steve are you having any luck?
                T.C.
                • RandyatBBY
                  • 3943
                  #68
                  I was asked by a friend/customer to find this thread, 67 post and no answers??? Did you all give up???
                  I am still running the old 40.160 they had problems at the SAW's with Neu's and high voltage.
                  I ran my 1527 .5Y in a 34 inch rigger with a m447 on a CC240 LV with no problems, But I felt it would not be a good idea to go up in prop at all.
                  Randy
                  BBY Racing
                  • RaceMechaniX
                    • 3024
                    #69
                    I got mine to all work with the computer, I think others were still having some issues.
                    TG
                    Tyler Garrard
                    • RandyatBBY
                      • 3943
                      #70
                      Once I get a little deeper in to the Conquest build I will see how it goes.
                      Randy
                      BBY Racing
                      • pmx
                        • Nov 2010
                        • 63
                        #71
                        Schulze said this is the latest Windows USB driver:
                        USB-ftdi driver for Windows (contains CDM20802_Setup.exe)
                        http://www.schulze-elektronik-gmbh.d...0802_Setup.zip
                        PDF of installation instructions.pdf
                        http://www.schulze-elektronik-gmbh.d...lation-ENG.pdf
                        Version: 02 DEZ 2010
                        Pops' fleet: Challenger 43, SuperVee 27, Pro Boat Fastech
                        Mine: JAE 21-FE
                        • urbs00007
                          • Jun 2011
                          • 857
                          #72
                          hi steve, are you the same steve reesor who video taped my record run in flynt early 90's x-hydro aluminum outrigger .? if so, how are you? I built a wood twin 90 outrigger (pinckert design) and powered it with a neu 2230 1 y 12 s . wasted months with china crap esc. now have a schulze 40.161 just bought. ran last weekend seems good. but cant get it to connect to my pc. to data log. downloaded recommended driver and program. when i plug in esc to pc nothing happens . any ideas?
                          • RaceMechaniX
                            • 3024
                            #73
                            urbs00007,
                            Are you using Akkusoft or the Futursoft program to access the controller?
                            Are you making sure to plug in the USB cable to the small white connector through the adapter? FYI, the direct USB port does not work on the liquid cooled versions.
                            Are you then applying power from the battery?
                            Tyler
                            Tyler Garrard
                            • urbs00007
                              • Jun 2011
                              • 857
                              #74
                              hi tyler, running schulze soft from their website . plugged esc to usb uni adapter to cable adapter to usb port on my computer. when i plug it in nothing shows up on my computer ( that a device has been plugged in ) do i need to power esc to get the computer to recognize connection?
                                • 7512
                                #75
                                If you are taliking about Steve Ressor from Ontario Canada, unfortunately, he is no longer involed in RC boats.
