Genesis stuffing tube damage
  • rotomoto
    • May 2010
    • 24
    Hi all, first post.
    I'm a FE boating newbie and like many others, have just gotten a Genesis Cat from
    HK. I checked the box and boat over and everything came through shipping great except for the stuffing tube. It looks like the box was dropped on the transom end and pushed the strut forward and kinked the stuffing tube.
    My question is, should I just replace it as it's set up from the factory or should I take the opportunity to change anything that might be lacking from the original setup. I don't know a whole lot about boats, so that's why I ask.
  • tiqueman
    • Jul 2009
    • 5866
    A lot may have to do w/ your future plans with it. However, I would maybe change it to .150 flex w/ 3/16 prop shaft if you plan on leaving it pretty much stock or similar. Also, you may begin to dislike the sq drive and what it takes to grease the shaft. Its quite the chore.
    OSE has all the product you need to swap out the tube. .150 w/ liner takes 1/4" tube.
    And welcome to the forums
    • rotomoto
      • May 2010
      • 24
      I plan on leaving it relatively stock. By square drive, do you mean the profile of the drive cable is square? I'll have to look at it.
      Is there any technique for removing the part of the tube thats epoxied through the hull? I don't want to do any damage.
      Thanks for the tips and the welcome!
      • bustitup
        • 3072
        we need pictures of the damage man....would get you more help
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3784
          I think I can help, I have one. But yeah, photos would help us understand the situation better.
          ________
          EYE / VISION FORUMS
          • FighterCat57
            "The" Fighter Cat
            • Apr 2010
            • 3784
            The cable has a square end that goes into a "hard prop shaft" that is captive in the strut. (the threaded steel shaft the prop goes on)
            The tube is easy to replace, some epoxy and some silicone and you'll be good to go.
            The drive setup is basically this one:
            http://cgi.ebay.com/Aluminum-rudder-...item414a685a38
            You can get the tube/cable all in one:
            http://cgi.ebay.com/4mm-x-350mm-driv...#ht_1721wt_911
            ________
            FERRARI F1 641 SPECIFICATIONS
            • rotomoto
              • May 2010
              • 24
              Thanks for the tips guys, I think this should be pretty easy to fix.
              One last question, if I change out the square drive, can I use the same strut that came with the boat? Thanks again.
              • Jeepers
                • May 2007
                • 2050
                an easy way to remove the stuffing tube is to heat it with a soldering iron it softens the epoxy and you can just pull out the tube, I use an 80 watt iron to do the job.
                • FighterCat57
                  "The" Fighter Cat
                  • Apr 2010
                  • 3784
                  If the new cable/wire drive is a 4mm drive or you drill out the strut to accept the 3/16 cable/wire drive and bushing, then yes.
                  ________
                  Sc2 Replay
