Help setting up syncron
  • aqad
    • May 2007
    • 1
    I am going to buy a syncron w/o harware and use this hardware
    http://www.offshoreelectrics.com/images/products/61.jpg
    I want a wery fast running boat with some stability left. Would rather not use lipos.
    Motor and ecs pack and prop suggestions?
    Would sv27 package work with syncron?
  • NorthernBoater
    • 869
    How many cells do you want to run. Here are some photos of mine.
    http://forums.offshoreelectrics.com/...read.php?t=361
    • Steven Vaccaro
      Administrator
      • 8932
      The sv motor package will work. It should run in the 35-40mph area with a x640 prop.
      Steven Vaccaro
      • NorthernBoater
        • 869
        Depending on how much you want to spend on the ESC and motor would really determine what would be the best setup. The SV27 system is going to be cheaper. A hydra 120 and an XL motor will outperform the SV27 setup but will also be more expensive. I started with the SV27 motor and changed it to a 9XL motor and I was much happier.
        • kck741
          • Aug 2007
          • 282
          I would start with the sv27 syshttp://www.offshoreelectrics.com/pro...d=dh-blcomboaqtem should run good on 12 cells
          S.S.R.C-Southern Style Radio Control
