brushless Outboard on a V hull
  • ON THE FARM
    • Mar 2010
    • 9
    I have a brushless outboard set-up that i am mounting on a 34" test v-hull.
    i have never mounted an outboard to a v-hull, so if you have done this can you guru's give me some advice?
    do i set it up so the cavitation plate is level with the bottom of the hull (lowest part of the V)?
    i know on a tunnel hull i have always set them up about 1/8"+/- above the lowest edge of the sponson.
    anyone have any tips and or tricks?
    THANKS
  • Eodman
    • 1285
    Check out the "pdf" on Aquacrafts site for the EP1 outboard if I remember right there's a diagram on mounting location of the outboard.
    It will give you a starting point!
    We did it with a Bang!
    Cats Are Where It's At!
