DF 29 M440+ MMM 2200 +6s = ok?
  • FastVee
    • 659
    Hi all, I just tested the boat with 4s pack
    That was heavy and in front of the motor, so cog was way off.
    Tomorrow I could test it on 40C 5000mAh 3S lipos(2x3S)-one pack both sides of the motor= good cog. -so 6S is next.
    What do you think, the esc is rated 6s and the 2200kv(rated 60.000rpm) should be ok for this size boat and the X440 is a small prop.
    I have x637,640 ,642 ,M445 and S220 props aswell. The s220 on 6s would be to much right
    so what would you do and what to expect of it...
    www.youtube.com/rangerpate
  • westbeach
    OSE Rocks!
    • 969
    Firstly kill that damn music..lol. A little annoying! She seems to run well, what were the temperature on the motor/esc? You could easily move up to a X/M442 and see how the motor handles the prop. And slowly work up in size. I would definitely try a S215, S220 as well.
    HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
    • ED66677
      • 1300
      get some 2S instead of one 4S you'll be able to get the COG under 30%, she's going to start flying!
      Emmanuel
      • FastVee
        • 659
        Firstly that annoying music or no sound -the first minute or so the camera recorded sound but after that it was silent.
        Motor was 45 deg.c.
        esc about the same, but the fan did kick in .
        (no water cooling used! )
        On 4s the x640 should work.
        But the question is will the 6s kill the boat . -that´s 55k rpm on full packs.
        I guess that I will find that out soon...
        And the 2S pacs... -I have 2 of 20/30C 5000mAh , so they might not provide the current needed. I dont know.
        • ED66677
          • 1300
          2200KV and 6S is more a SAW configuration than anything else!
          two 20/30C 5000mAh 2S is not bad Pate... that's what I'm running on my 29" DF copy, but not with 2200KV, I have a 8XL, KV is around 2080 so I can spin a bit bigger prop than you probably can!
          Emmanuel
          • FastVee
            • 659
            The 6S configuration would be just to see how fast it is......
            So naturally I would like to test it.
            The 8XL(feigao) and 2200 castle/Neu are so different motors that I cant compare the 2.
            I had 8XL on 32 hotr cat on 4s, but this 2200 looooooo-oong can feels much better quality, -runs cool and the sound is... great. -but I cant really say cause I have not had the 8Xl on this hull.
            Castle says this combo draws about 4-5KW so I really think the 20c batts are too small.....
            • tth
              • Apr 2008
              • 1600
              I wouldnt do the 6s......too risky on that power combo in a mono. Thats just me tho.
                • 9481
                strang you are running 6s on a 2200 Castle motor and only getting these speeds
                there are some DFs of youtube running a 8XL on 4s that look faster..
                but the Castle on 4s with a S220 would fly!
                • FastVee
                  • 659
                  So maybe I should test the s220 and 4s first? -and if that wont move it in with the 6S
                  So the next test will be with these:
                  • Rumdog
                    • 6667
                    I run 2 of those motors in a twin cat. Each on 5s1p and x447 props. They are cool as can be after a 3 minute run. I am by no means condoning 6s, just my findings on 5s. They truly are 4s motors in a boat. Definately are gonna want the water jackets from ose though.
                    • Rumdog
                      • 6667
                      I'd stick with 4s and get a x445 prop and water cooling.
                      • Doug Smock
                        • 5359
                        [QUOTE=FastVee;187619]
                        QUOTE]
                        No sir, the BOAT will probably be fine, it will stink, but other than that.....
                        That is a 4s hull and motor. Put a wheel on it and run it someplace where it can breath. Get a M445, you may have to back cut it approx. 1mm.
                        6s with that motor is hot for even a SAWs setup.
                        "Learn not to burn" LOL
                        Have fun and be safe!
                        Doug
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                        • FastVee
                          • 659
                          I just checked and I do have M445(not yet balanced), but what do you guys think of the s220, ok to try? -few second run and temp check.
                          I will get another esc soon that is better suited for boats, another himodel 200A I guess.
                          And for the motor I will get the cooling jacket, but dont have one yet. The motor stays cool on x440 atleast. -and I did add cooling to the mount after that run(I know that is not as good like proper cooling jacket ,but it will cool it a bit).
                          AND THE PROP USED ON THAT VIDEO WAS X440 NOT M440, SORRY !
                          • FastVee
                            • 659
                            Interesting.
                            Just returned from the sea and here are the results on 4S
                            S215 63.7 km/h ~39 mp/h
                            S220 79.7 km/h ~49.5 mp/h
                            Temps, motor max was 27 C and the esc was 34 C. -only cooling was done using cooled motor mount.. .-and water did cool a bit after the hatch tape ripped off on one side, after that dive on the video. -Glad I had coated the esc and rx with electronic lacker.
                            Gps off... well it was faster but it went flying and diving
                            so I guess that the S220 with proper tuning will get this thing going.
                            and to the video ----> http://forums.offshoreelectrics.com/...159#post188159
                              • 9481
                              I knew it!
                              and your temps are awesome..
                              could get away with a S225 for even more speed!
