Just tried it, yes it does. It re writes the key in the registry, probably with correct values.
help with fecalc
Great!!!ReddyWatts fleet photo
Open this file and see if it has your equipment in it.
You can replace the text file in the fecalc directory with this one or add your equipment to it manually.Last edited by ReddyWatts; 06-06-2010, 10:27 PM.ReddyWatts fleet photo
I put used that file, had to modify it to get a couple of the things I have in there. I now have tow questions. One, if I use two 3s packs that are 5000mah should I input the battery is 10000mah or just 5000? Second, with the motor I inputed (a fieago 6xl 2871v/rpm) when I run the prop wizard, it just comes up with "text 1" in all the boxes on the results page.
It was very helpful to do the calc with this to see what amps I am pulling.
Thanks in advance.
For 2P: volts stay the same, double the weight and mah, divide cell resistance by 2.
The text1 usually appears when your setup is out of range.ReddyWatts fleet photo
