oval master 21" motor/prop advice
  • Alexgar
    • Aug 2009
    • 3701
    i have a ovalmaster 21" and i want to change my motor. My otions are a 9l on 3s or a proboat stock motor on 4s. And what prop should i use on each
  • Alexgar
    • Aug 2009
    • 3701
    bump
    • D. Newland
      • Dec 2007
      • 1066
      The size of the boat is really going to limit you to smaller props. Like, X435, X435/3, which are 1/8" prop hubs.
      If you are looking for a 3/16" prop hub, X438, X637 x537/3 are good choices, too. All of these props will work with what you are wanting to do above, and not make that boat TOO fast.
      The 9L will spin faster on 3S than the Proboat motor on 4S, so favor the smaller props w/the 9L setup.
      I used to run the 9L on 12 NiMH cells with an X440 (race setup) in an OM 26, so I don't think a 9L on 3S with an X438 in the smaller boat will be a problem.
      You'll need a min of a 60 amp ESC. 80-100 would be better, and quality cells, too.
      The Proboat motor on 4S will give you more options down the road. It's a more popular motor that has a better Kv on 4S to allow a much larger prop selection...when you get a bigger boat.
      • Alexgar
        • Aug 2009
        • 3701
        i actually have a bigger boat but have been haveing problems with esc and props in this boat but ill try your advice
