Electric fan cooling for codite SS1
  • arrowskartax9
    • 130
    Hello everyone, can you use a fan cooled heat sink on a cordite ss1 in an enclosed mono??
  • egneg
    • 4759
    The motor has a fan built in.
    IMPBA 20481S D-12
    • Simon.O.
      • 1611
      You can if you like, if you need to cool the motor then it is often better to cool with water via a coil or better still a jacket
      That internal fan does a lot of cooling too. I have one and have used it a lot.
      If you need more cooling then go with water.
      I used a coil over the torque ring and then water-cooled the brush tabs too.
      • arrowskartax9
        • 130
        Thanks Guys for replying. Iwill give the watercooling a try.
        • Karfrik
          • Jun 2009
          • 1248
          I`m with Simon,do brush tab cooling,that would be enough.If not add coil cooling.Both easy to dot yourself.Just check OSE store "tips" section,....Al
