Proper way to install a stuffing tube?
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    I'm re-inserting the stuffing/drive tube on an apparition. It looks like the hull cracked when they originally set it up or when the prop shaft broke. I don't recall which.
    It was originally glassed in with small fiber cloth, but quickly cracked loose when the prop shaft bent and vibrated it loose.
    Should I use marine epoxy or fiberglass resin w/small cloth? or is there another way completely?
    ________
    NEW MEXICO DISPENSARY
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    Silly question I know, but would like another mind on it before I lay the glass.
    ________
    Yamaha Fz750
    • Shooter
      Team Mojo
      • Jun 2009
      • 2751
      I use Z-Poxy and one pc of glass over the top of the tube. Make sure you sand everything that will contact the epoxy (including the outside of the brass tube). You can put a few pcs of tape on the other side of the hull (bottom side) while the epoxy is hardening. That will give you a clean finish on the bottom as no epoxy will leak out. See attached of my repair. Good Luck!
