Esc cutting on and off
  • ezhitz
    • Aug 2009
    • 466
    Tried my new SeaKing 120 amp in my rigger today and it would cut in and out.
    Sometimes I would go a lap or two then cut out or just throw it in and go a couple of feet and stop.If i would wait a minute then it would go again. The temps where never above 105f I'm running a 7S feigao timing is set at 7.50 degrees and the lvc is 3.4v/cell.i did manage a couple of gps readings today.
    :canada
  • LiPo Power
    DJI Drone Advanced Pilot
    • 3678
    Is it cutting ussually when full throttle?
    Canada
    • ezhitz
      • Aug 2009
      • 466
      yes it is or if its already stop when i wait then give it throttle it will come up on
      plane and stop againhttp://www.youtube.com/watch?v=REitCZmOtjc.Heres a little clip where its was running and died coming out of the corner.
      :canada
      • LiPo Power
        • 3678
        I had this going on on my UL-1....
        Could not find the reason for cutting off on me...
        The problem was...... CAPS!!!!
        Went to my little shop and installed more caps. Result , no more cutting off and on.....
        I am not saying this is your problem in your case but it was with my ESC. Look in to it. Maybe it is as easy as adding new caps....
        Robert
        PS
        Read here:
        http://forums.offshoreelectrics.com/...ead.php?t=9828
        Canada
        • ezhitz
          • Aug 2009
          • 466
          Thanks LiPo I will look into that it won't hurt to add one plus my son
          puffed two on his turnigy 180 we nead to repace also.
          Thanks
          :canada
          • LiPo Power
            • 3678
            What set up was the Turnigy 180 running?
            Thanks
            Robert
            PS
            Where are you in Ontario?
            Thanks
            Canada
            • ezhitz
              • Aug 2009
              • 466
              In brampton, He running a 7Xl on 4S with a X440 in Osborn Miss Supertest
              30" hydro. A lot of on/off and half throttle running to keep it on the water.
              :canada
              • Raydee
                • 1619
                Did you try turning off the low voltage cutoff? I read before about that controller having a problem with that.
                Team Liquid Dash
                • Xfactor
                  • 874
                  Check for solid connections, bullets etc.
