Cant we do this?
This topic is closed.
  • sailr
    • 7128
    another thing interesting about the hifei aircraft controller, at least in the 55 and 75 amp versions I was playing with the other day, the two boards actually PLUG IN to each other. Not soldered. They will separate easily. In fact I took a 55A with blown FET's (dumbass me, I plugged it in backwards) and a 75A with a bad BEC and used the good part from each one, plugged them together and I'm back in business!
    Mini Cat Racing USA
    www.minicatracingusa.com
    • domwilson
      • 4411
      I'm interested if Xfactor can make this work. I'm seeing guys on here being innovative in their solutions to problems all the time and I wish him good luck. He may have a trick or two up his sleeve. Xfactor, there are a number of BL ESC schematics on the internet that may assist you in your endeavor. Good Luck...
      Government Moto:
      • domwilson
        • 4411
        Correct me if I'm wrong, don't the sensored motors and ESC's use Hall Effect sensors? What's a Benz controller? Do you have any pics or links?
        Government Moto:
        • Xfactor
          • 874
          Thats wat i call a shulze because they really make hybrid esc's for BENZ's
          • Xfactor
            • 874
            Yes they do use hall. To impliment that on a sensorless brushless motor migh take a little thought. First thing you need to know is what kind of hall is a shulze compatible with. I opted for optical because I can impliment that on the screamer easily. With maybe a neu type motor I might see if Randy or someone can machine me a collet with positioning magnets?????Or you can order a custom motor with a shaft that protrudes out the back and design you hall setup there. Its do-able and worth it.
            • domwilson
              • 4411
              Government Moto:
              • Xfactor
                • 874
                I wonder if I could use my pull with the alternative fuel sector at school and get those rich rascals at shulze to donate me a working sample for r and d. Dont laugh companies will do it. I got a noritake graphic lcd that way. It shows animation like the dolphins on a pioneer deck. Thats a 175 dollar screen. Now how much does a cd player for a car cost with a part that alone cost 175 dollars? think about it. To make a thousand of them in just that part cost what? 175,000 dollars.
                • Xfactor
                  • 874
                  Trust me when I try to tell the fellas something some times I do know what Im talking about. And if I dont teach me. If neither of us know lets test it out. Gives me more excuses to run boats
                  • Xfactor
                    • 874
                    Oh dont sleep on novak im truly surprized yall dont fool with it.Probably because hv to them is 6s.We bust stuff up in boats.
                    • domwilson
                      • 4411
                      So if you parallel the MOSFET's on the output, are you going to incorporate some type of current limiting and/or temp sensing? From what I understand, that is done in the firmware as well as the hardware.
                      Government Moto:
                      • Xfactor
                        • 874
                        It is done in both .May as well why not id have too if I want a datalogging feature onboard anyway.
                        • Xfactor
                          • 874
                          U cant do it all in one shot u get the basics running first then go to the more sophisticated stuff.What ever happened to that proposed scorpion 300 amp joint.
                          • m4a1usr
                            Fast Electric Addict
                            • 2036
                            Jim, thats pretty damn clever! Any connections at HiFei that might be able to tell you if the 240 might be "home" upgraded? If the 240 could be made a 360 for $500 it would look way more appealing then a $800 40.300.
                            John
                            Change is the one Constant
                            • domwilson
                              • 4411
                              Dunno.
                              No new news to report. But here is something to look at...
                              Government Moto:
                              • domwilson
                                • 4411
                                After you get that ESC going, you can use this...
                                Government Moto:
